7x18 vnose Diamond cargo with pics
Re: 7x18 vnose Diamond cargo with pics
Postby MyYota85 » Fri Mar 13, 2015 9:25 pm
Got the hole cut, measured about ten times and cut once, just had to trim a hair on one of the corners. Tin snips did the job for that. Bought some SS screws and put three up top and three on bottom.
First pic is just sitting in and the second is all screwed minus the silicone
MyYota85
Postby MyYota85 » Sat Mar 14, 2015 6:48 pm
The inside view of the window, it didn't come with trim so I'll have trim with wood. And the shower is almost framed up.
MyYota85
Postby MyYota85 » Tue Mar 24, 2015 9:06 pm
Got the water inlet and electric inlet installed today.
MyYota85
Postby Rainier70 » Wed Mar 25, 2015 8:46 am
That panic feeling when you go to start cutting holes in the sides is the hardest part. Looks like you breezed through it.
Rainier70
Images: 244
Postby lrrowe » Wed Mar 25, 2015 1:24 pm
I still have not gotten over mine enough to start my cuts. Fortunately I have plenty of other tasks to focus on.
Bob
lrrowe
Images: 439
Postby Prem » Wed Mar 25, 2015 4:27 pm
:D I love putting in RV windows!
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby MyYota85 » Fri Mar 27, 2015 1:21 pm
I've got one more window to install if YA get bored prem!
A lot of things have been getting done including ceiling is painted countertop is on upper and lower cabinets installed almost all water related piping is done and all lighting is almost done.
MyYota85
Postby Prem » Fri Mar 27, 2015 9:19 pm
Would love to. Just buy my airfare.
:lol:
My goal...
Prem
Images: 144
Postby MyYota85 » Mon Apr 06, 2015 7:32 am
Sorry prem, that's not in the budget for me. I did get the last window installed. Started sanding all the wood for paint. Got the desk built and pre mounted it.
MyYota85
Postby MyYota85 » Sat Apr 18, 2015 9:58 pm
I've got about everything finished. All that is left is the trim work. My first trip is this coming weekend.
MyYota85
Postby MyYota85 » Sat Apr 18, 2015 10:00 pm
Here's a quick shot at the almost finished product.
MyYota85
Postby MyYota85 » Sun May 17, 2015 11:58 am
Well I'm basically finished with my conversion minus the painted trim work. I've been sleeping on a huge blow up mattress UNTIL this weekend. Man this 6"gell cooled mattress is comfy. I mounted it on four of these struts from the back of a pathfinder door. And then four gate latches (2 was to shaky). So up and outa the way my rzr has prop 3" of clearance.
MyYota85
Postby MyYota85 » Sun May 17, 2015 11:59 am
And here it is down in sleeping mode.
MyYota85
Postby Gunman9 » Sun May 17, 2015 1:34 pm
MyYota85 wrote:And here it is down in sleeping mode.
Where did you get the shocks to build the bed and how was it set up?
Gunman9
Postby MyYota85 » Mon May 18, 2015 7:23 pm
My wife drives a Nissan pathfinder and i had to replace the 2 struts on her back door. So i did some measuring and found that 4 of these would work perfect! to get the bed up or down i just slide it in toward the inside of the trailer as the bed pivots up/down. the up part is a bit to awkward.
My next ? has any one used the trailer weight distribution hitch? my problem is I've got literally 0"S of tongue so no way to mount it? I'm looking at this and maybe welding it to the trailer frame?? good idea bad?? http://www.ebay.com/itm/Pro-Series-4990 ... 2d&vxp=mtr
MyYota85
