1. When running wiring what is the best way to run it to outlets/switches in the walls? Come along the bottom of the trailer and up into the void between the studs? It doesn't seem like a good idea to drill a hole through each of the wall studs to run the wiring through the wall. Are there any waterproof boxes that would allow plugs in the floor?
2. Since the depth of the wall is only a couple of inches what kind of boxes, switches, and outlets do you use? It seems the standard ones used in houses will stand proud from the wall covering quite a bit.
3. I plan on installing insulation in the walls, but first need to put in wooden blocking to mount electrical boxes, hinges, and ETrac. How do you fasten the blocking in the wall? Can you glue it to the stud and outer skin? What kind of glue to use?
This forum is a fantastic resource for those of us starting on the journey, and I thank you all for your information. I am sure I will be here frequently as I proceed, since there is a lot more that I do not know than that I do.
