by noseoil » Fri Apr 17, 2015 9:47 pm
Have to agree with veneer core plywood in general. The MDF core just isn't as good structurally & weighs more. If it added weight & strength, that would be a different situation, but it doesn't. The import veneer core is a better product in general, with more going for it in this application. Nice work with the router on your panels, they look great.
I'm using 1/4" BB plywood as a combined bulkhead & structural (shear) panel between the galley & cabin. The walls, floor & top rib (the hatch rib in this case) all make up the framework with dados & the panel is the reinforcement in the middle. Cabinets attach to the front & back of the bulkhead (a common backing for both sets of cabinets). It adds to the structural strength (twisting) and saves some weight.
