angib wrote:rowerwet wrote:I know it would make an odd shape, but you could avoid a tounge all together by making the four corners of the tear cross section taper in together to the coupler....
That's more or less what I did with this all-plywood design where there is a structural tongue box that becomes the coupler. Of course, it isn't structural if it has an opening (except in the back) so it just looks like a tongue box, but doesn't open like one.
The red bits are metal as it's hard to avoid using metal to provide very local reinforcement - metal bolts are also good, as timber bolts have a bad reputation.......
Wobbly Wheels wrote:Check out the Canadian-built Orca fiberglass trailers - their shells are similar though they use a 2X2 tubular frame.
