Slipstream
Re: Slipstream
Postby KCStudly » Mon Apr 13, 2015 6:44 am
Suggestion: consider putting the water tank and battery closer to the axle center line. The less weight at the extreme ends the less wag potential. Also, the water tank is "variable ballast" so changes in tank level will have a greater effect on tongue weight if placed at the back than if placed at or near the axle.
Nice chalk drawing. :thumbsup:
Re: Slipstream
Postby Robot » Mon Apr 13, 2015 7:09 am
I've been hearing similar advice from some truck driving friends. The bed will reach over the axle almost to the door, so I will be able to fine tune the position of my ballast as needed.
Robot
Re: Slipstream
Postby Robot » Thu Apr 16, 2015 7:11 pm
I got the end pieces mocked up and set them on the frame to get my first visual of the profile. The front will be closer to the hitch, I just can't set it there till I get the floor built.
Robot
Re: Slipstream
Postby garyc1955 » Thu Apr 16, 2015 10:18 pm
Very interesting,what kind of car do I see ,Triumph maybe?Gary
garyc1955
Re: Slipstream
Postby Robot » Fri Apr 17, 2015 12:00 am
That's my daily driver, a 1966 Volvo 122s wagon. It might pull occasional tow duty to local car shows depending on the weight of the finished trailer. I have a deep love for this car. Reliable, easy to work on, surprisingly quick and a real blast to drive. I have owned a lot of 60's cars but the Volvo is getting passed down to my kids one day.
Robot
Re: Slipstream
Postby noseoil » Fri Apr 17, 2015 7:48 am
Amazon! Too bad you can't do a B23FT swap and use that for a tow vehicle.... Just a thought, but it would be great on hills & on the freeway.
137905
noseoil
Images: 670
Re: Slipstream
Postby Robot » Fri Apr 17, 2015 8:16 am
I have a B20 with an overdrive tranny out of an 1800s waiting for a rebuild....that's my next project after I finish the trailer. There are a number of technical hurdles to overcome when swaping in a later drive train, but the B20 bolts right up and makes plenty of power. With the low gears on the wagon I think it will likely tow the trailer just fine. I just need to fab up a hitch. No off the shelf options.
Robot
Re: Slipstream
Postby Pmullen503 » Sat Apr 18, 2015 1:02 pm
Interesting technique.
Do you plan to add the foam skin between the pipes or over them? How will you handle the rounded corners?
Pmullen503
Images: 67
Re: Slipstream
Postby Robot » Sat Apr 18, 2015 6:47 pm
The rigid foam sheeting will be outside the pipes.
The corners. That's the big challenge.
I was going to try to heat form the foam around a large exercise ball. But I see now that's not going to work. Online I found steel ball corners from a trailer supply place in a variety of sizes. They have 12" radius which should match my arcs perfectly...the steel drum I used for my form has a 24" diameter.
I'll use the steel corner as a female mold and fill the inside with a can expanding foam.
I'm going to check with a local trailer supply place and see if they have the corners in stock so I can save on shipping and hopefully return it when I'm done.
Robot
Re: Slipstream
Postby noseoil » Sat Apr 18, 2015 7:19 pm
You might consider what was done way back for making surf boards out of foam. A sure-form (like a hand-held cheese grater) makes quick work of foam. If you had a template for the outside (1/8" masonite or even cardboard) you could free hand the curves to get close enough.
137905
noseoil
Images: 670
Re: Slipstream
Postby Robot » Sat Apr 18, 2015 8:08 pm
Hmm. That sound like it's worth a try. I'll put some saran wrap on the big exercise ball, cover a corner's worth in foam, let it cure, and have at it with the power sander. At the worst I'm out 4 bucks for the can.
Robot
Re: Slipstream
Postby Robot » Tue May 26, 2015 2:08 am
Progress has been slow due to non-stop rain in central Texas over the last month. I have been working on it when weather permits. I'm about a month and a half away from my deadline. The PVC skeleton is done, still working on the door. I began steam bending the foam sheeting today before I got rained out.
Robot
Re: Slipstream
Postby dales133 » Tue May 26, 2015 3:11 am
Looking good. I'll be watching this with intrest
dales133
Re: Slipstream
Postby booyah » Sat May 30, 2015 8:07 am
Digging this, love the idea of the bent PVC for the frame Pretty neat
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Re: Slipstream
Postby Fred Trout » Sat May 30, 2015 11:17 pm
Great concept; will be following your progress with interest :D
Have you decided how the foam will be attached to the PVC or will you rely on the exterior canvas shell to keep the entire unit in place ? How do you plan to finish the interior ?
Fred Trout
