Paddy Shepherd wrote:Not quite sure where you got that 60kg from buddy but thank you for the info on the strength.
I just looked at some marine ply (although I will probably just use normal) and the weight of that for a 4' x 8' sheet in 5mm (3/16") thickness was 16lb according tho the specs, which is approximately 7.5kg.
ctstaas wrote:Hi Paddy, Whats up?
A few suggestions from me; Some take 3/4" sheets and cannabalize them and add insulation to the cut outs and thin sheeting to the inside and out before skinning the outside in Al. Mine is just 3/4" marine grade plywood with no insulation in the walls. When you cut your outside shape do them together so no matter the final shape they will both be the same. It will really help later in the build. When I rolled the cabin onto the frame I was thinking " I could make it detachable and have a multi-use trailer", but that thought didn't last long. For you, Oh yeah, consider light and fender placement and your good.
I would move my galley opening back farther. You could fit five kegs in your proposed galley. Five kegs is the right amount of beer but you need some space inside the cabin so its a trade off. Really, My galley barely fits my icechest with the hatch closed so I dodged a design bullet there, so my advise is to make your galley space accommodating for you essentials but be gracious for you sleeping quarters, it might rain.
I love TD's because they provide super function with high design attributes. I'm sure you'll get an A on your project.
Enjoy, Chris
S. Heisley wrote:Hi, Paddy. I think you're smart to want to park your bike inside your teardrop.There are gangs that are stealing bikes at unheard of rates, all over the nation. If they can't get them off the bike rack, they steal the rack too. Last fall, police found an area, in a canyon behind a local hospital, that contained parts from 2,000 presumably stolen bikes.
