bc toys wrote:Why not move it back a little to the rear just behind your do because if it rains with a EZ up water will run right in your door when you open it and thats my .02$ if you must raise it get you some square tubing that just slides over the small tube leg and cut off the bottom weld a end cap on the new tube and slide it up tell you get the hight you wand drill 2 holes about 2'' apart the bottom being the hight5 you like and the upper be incase the ground is a little lower in places mark the leg on the Ez up with the bottom hole and drill hole there and get 4 pins with fasteners that way they can be removed when you fold up the Ez up
