Stepping into the TearDrop void
Re: Stepping into the TearDrop void
Postby Sheddie » Thu Apr 09, 2015 6:39 pm
Yes, that's who our doors came through as well.
Working around home today. Looked at the weather forecast earlier in the week and decided it may be a bit damp today for mowing at the fert works :rainy: so got stuck in and crammed all of todays work into the last couple of days. It is not too bad so far today, but looking north, the hills on the other side of the swamp (where the swamp marlin live), are starting to look pretty wet, and it is heading this way.
Sheddie
Images: 1129
Postby trailtroll » Mon Apr 13, 2015 9:54 pm
Worked on the tongue box and mounts today, also trial fitted the doors.
Also looking at lining the inside with this product, I think it will look quite nice, http://www.wovenbamboo.co.nz/woven-bamb ... 24_26.html
we are looking at the WB panel, last one on page. $62 a sheet, 2.440x1.220.
Chose to go with a slightly larger tongue box so we can store, battery, gas bottle (3kg), cooker and odds and sods, like jack etc.
Well back to it.
:vroom:
The doors having a trial fit
Trial fit doors.JPG (132.28 KiB) Viewed 1391 times
removeable tongue box
tongue box1.JPG (186.21 KiB) Viewed 1391 times
I woke up this morning and all of my stuff had been replaced with exact replica's
trailtroll
Postby Sheddie » Tue Apr 14, 2015 6:22 am
That bamboo ply could be ok. Do you know how flexible it is to go around the front curve? Out of the options that was the one I picked as well, but I would like to see it as a full sheet, as in the confinement of the interior of the TD it could be a bit busy and give the impression of a much smaller place.
I bet you were excited when the doors arrived.
That box is a good size you should get plenty in to that, gust be conscious of the amount of weight. If you put your battery in there, don't forget to have it well ventilated.
You are coming along well :applause:
Sheddie
Images: 1129
Postby dales133 » Tue Apr 14, 2015 6:45 am
From my dealings with woven bamboo it's fairly springy and I'd recommend using the 2mm and even with that I'd check the bendiness of it first
dales133
Postby trailtroll » Tue Apr 14, 2015 10:24 pm
To all, I have a sample, and the 3mm 5ply is as bendy as I require for the curve.
I have since found an Auckland supplier at $49.50 per sheet plus delivery.
The bamboo pattern is quite small on the sheet, so it shouldn't get to busy.
:vroom:
trailtroll
Postby trailtroll » Wed Apr 15, 2015 1:30 am
Frank, what would be the best and water-proof way to vent the box,
:vroom:
trailtroll
Postby Sheddie » Wed Apr 15, 2015 3:37 am
trailtroll wrote:Frank, what would be the best and water-proof way to vent the box,
:vroom:
I would probably create a separate area in the box sealed off from the rest of the box to stop the fumes getting to the other area. Put air vents at the top and drains at the bottom.
Sheddie
Images: 1129
Postby dales133 » Wed Apr 15, 2015 4:03 am
Use those louver style punched metal type vents they are avaliable in steel or aluminium.
You what I mean they used to be used alot in nz on doors and stuff in schools ect
dales133
Postby Sheddie » Wed Apr 15, 2015 2:31 pm
dales133 wrote:Use those louver style punched metal type vents they are avaliable in steel or aluminium.
Or something like the the little black ones (I think they have other colours) we have in the side walls each side of the galley. We got them from Burnsco.
Sheddie
Images: 1129
Postby dales133 » Wed Apr 15, 2015 2:56 pm
What have you got them in the galley for?
dales133
Postby Sheddie » Wed Apr 15, 2015 5:23 pm
dales133 wrote:What have you got them in the galley for?
Air circulation for the 12v chiller when the hatch is shut.
Sheddie
Images: 1129
Postby dales133 » Wed Apr 15, 2015 5:32 pm
Ahhhh. I was going to put my fridge in the galley but decided against it as it would mean to many compromises to my layout.
I got a new Waco icebox the otherday that's 24 liters and my old Waco the same that's 13 for the galley and my fridge will go on slides on the drawbar over the top of the batteries at this stage
dales133
Postby trailtroll » Fri Apr 17, 2015 12:27 am
Busy again today, finished the tongue box paint and mount, also trial fit cupboards & internal power-points
:vroom:
Cupboards
Inside cupboards and power points
Tongue box fitted
trailtroll
Postby KCStudly » Fri Apr 17, 2015 6:51 pm
Looking good. :thumbsup:
Postby dales133 » Fri Apr 17, 2015 6:58 pm
Nice job on the cabinetts, looking good
dales133
