bobhenry wrote:Here is a further explaination of the drip leg.
I had problems with this fireplace
and finally called in professional help. The furnace guy was even almost at a loss. He was finally convinced the orifice was clogged. I stripped a very fine stranded wire and pushed it thru the opening. I couldn't tell any difference but we reinstalled it and it worked. He pointed out that my 1/2 steel threaded pipe goes directly to the flex gas line. He suggested I re-plumb slightly by removing the upsweep ell and replace it with a tee fitting and add a 4-5 inch nipple with a cap pointing down. This "drip leg" gives a place for heavy particles to fall and get out of the gas flow. Seems the rust and crud in the pipe just needed a place to get away.
MtnDon wrote:The valve between the regulator and the cylinder is not needed. The cylinder has a shut off and that is all you need before the regulator. You use that to shut down the gas supply.
OTOH, when or if there are more than one appliance (range, furnace, water heater, etc.) a valve just before the connection to the appliance can be handy in case service is required. That can avoid shutting down the whole system if one piece needs work.
G2419.4 Sediment trap. Where a sediment trap is not incorporated as part of the gas utilization equipment, a sediment trap shall be installed downstream of the equipment shutoff valve as close to the inlet of the equipment as practical. The sediment trap shall be either a tee fitting with a capped nipple in the bottom opening of the run of the tee or other device approved as an effective sediment trap. Illuminating appliances, ranges, clothes dryers, decorative appliances and outdoor grills need not be so equipped unless specifically required by the appliance manufacturer's installation instructions.
capnTelescope wrote:I included a drip leg in my piping install. It's in this post.
It looks like this:The end on the right is the drip leg and points down. The tee gets the pipe from the tank. The other nipple goes up to my appliances.
Note the yellow pipe goo. That's the kind they want you to use for gas pipe sealant. It'll say its for natural and LP gas. Works for water, too.
zroadhouse wrote:Is the leg part under the trailer and pointing down in your install?
