Stepping into the TearDrop void
Re: Stepping into the TearDrop void
Postby trailtroll » Sat Apr 18, 2015 4:22 pm
When setting up a 12v lighting system, do I need to earth each item I install, or can i just run the positive and negative wires to each item, and use the + & ~ poles on the battery?
:vroom:
I woke up this morning and all of my stuff had been replaced with exact replica's
trailtroll
Postby Sheddie » Sat Apr 18, 2015 8:46 pm
Just run twin core wire from the lights back to your fuse box. I have a fuse box under the galley bench with a heavy wire going from that to battery +, and a common terminal for the earth side with heavy wire from there to battery -.
Sheddie
Images: 1129
Postby dales133 » Sat Apr 18, 2015 9:04 pm
Yea I've done pretty much the same thing.
I have a negative buss bar separate to the fuse box (some fuse box's have negative and positives buss are included and even switches).
You can run more than one fuse box depending on how much you want to connect .
dales133
Postby trailtroll » Thu Apr 30, 2015 9:44 pm
I have been quite lately, been on holiday to the batch in Coromandel, now I am back working on the teardrop, just waiting for the Bamboo Ply to be delivered so I can line the inside, then the outside liners & Roof can be glued and screwed in place.
:vroom:
trailtroll
Postby Sheddie » Fri May 01, 2015 2:30 am
Snap! We just had last weekend touring around Coromandel with our teardrop. :D
Sheddie
Images: 1129
Postby trailtroll » Sat May 02, 2015 12:18 am
Where on the Coromandel were you slinking away too?
:vroom:
trailtroll
Postby Sheddie » Sat May 02, 2015 3:05 am
We had three nights away, one in Miranda, then Shelley Beach just out of Coromandel township, and at Cooks Beach.
Sheddie
Images: 1129
Postby dales133 » Sat May 02, 2015 5:53 am
Did you find my swimming hole?
dales133
Postby trailtroll » Sat May 02, 2015 2:25 pm
We were in Coromandel town-ship it's self, Maggie's family have land there. That is where our batch is.
:vroom:
trailtroll
Postby Sheddie » Sat May 02, 2015 4:04 pm
dales133 wrote:Did you find my swimming hole?
Didn't really have time to look, and the weather wasn't all that encouraging for swimming, except in the hot pools at Miranda. The hill across the road from the camp is still covered with bush, but there are driveways going up to private residences hidden in the bush.
Sheddie
Images: 1129
Postby dales133 » Sat May 02, 2015 6:13 pm
Grŕrrrr nothings sacred anymore
dales133
Postby trailtroll » Sun May 03, 2015 12:41 am
Frank, you went past our bach on your way to Shelley beach, we are opposite the road to the stamper battery at the top end of town.
:vroom:
trailtroll
Postby Sheddie » Sun May 03, 2015 5:53 am
I remember seeing the sign for the stamping batter.
Sheddie
Images: 1129
Postby dales133 » Sun May 03, 2015 6:47 am
I've been there a bunch of times as a kidlit
dales133
Postby trailtroll » Tue May 05, 2015 12:15 am
Today, 5th May, I have done the internal lining, Bamboo Ply, and the outside insulation, next will be the wiring, until I save up enough to purchase the outside cladding.
:vroom:
Bamboo Ply Lining
Insulation glued in.
trailtroll
