Could you please share such sources of information that have detail drawings of various junctions weatherstripping of RVs, TTTs, etc.?
Thanks for help.
KCStudly wrote:
Convention says that you only want to compress a seal about 1/4 to 1/3 of its free height, in order to preserve its springiness and maintain a long lasting seal.
KCStudly wrote:For a lifting roof that clam shells over the lower cabin?
Some people will use garage door seals that are much bigger and have either a large flap or a big soft bulb.
If I were doing something like that I would try to have raised sealing surfaces at the open and closed positions so that the seal registered more positively in those locations but did not sweep so hard, or even touch at all over the transition. My thinking is that this would save on wear and tear on the seal and would help keep the finish on teh sides from becoming scratched or discolored where the seal swipes by.
KCStudly wrote:My assumption, and from looking back at your initial sketches on your build thread, was that your lifting roof sides would be outside of your lower fixed walls, and that you are asking for a way to seal between the two, side by side (like in Sect A of the Winter Warrior plans, pg 7).
In your sketch above, I'm assuming that this is for the folding hard wall filler sections. I would think that the 'D' shaped hatch seal would work well there; just dado a groove wide enough for the seal to compress and to prevent the seal from over compressing.
For the sweeping side seal, such as for a Winter Warrior, upon review it looks like the plans just call for a brush style sweeper. This is where I was thinking that people have used the garage door style seals (IIRC). My thought was to position the seal so that it does not contact the sides, and to have raised areas, or beveled ramp strips, where the seal comes to rest at the ends of the hatch travel. These ramps would take up the extra clearance and give the seal a spot to land. With only 6 mm (or 1/4 inch) clearance between the inner and outer that might not be very practical and still have room for both clearance and seal compression.
