Gunman9 wrote:Hi yall,
I'm new here and just ordered my first CTC from a dealer here in Hampton roads, VA. The trailer I ordered is a 6x14, single axle, black, freedom trailer. I got a lot of options put in the trailer so all I really need to do once its done is insulate, cabinets, floor, paint, bed, and slide my window ac unit in. I had the factory install 2 4ft LED lights, exterior light by the door, RV door, Ceiling panels, 24x24 access door, stabilizing jacks, complete 30 amp electrical package, 5 receptacles, and a 30x30 window. Now I was cautious about the 30 amp system but they said they will include an adapter that will plug into 15 amp sockets for use at home or other places that do not offer 30 amp service. They also said I should be able to run the AC, fridge and lights with no problems. Does this sound right? I have been lurking around here for awhile now and have read literally all the way back to the 32 or so pages of threads. I believe I got almost everything necessary from the factory that one could need when converting a CTC. If I am missing anything please let me know! Also.... what kind of tv antenna are yall using? I deer hunt which is right in the middle of football season lol so I need tv to watch the games. Thanks!!
Gunman9 wrote:Irrowe,
I hear ya man! I can understand that. I always worry about particle board and MDF getting moisture on it and molding or falling apart. I have the kreg jig set actually and build a lot of farm house tables. I thought about going that round and building a custom cabinet set with a farm house table top. Here is a picture of one of my recent tables.
professorkx wrote:Gunman9 wrote:Irrowe,
OK, you've got the skills to build your own, no problemo...
In my mind, price is not the only factor to consider:
1. Weight is a big consideration, especially if you are putting you cabinets in the front to maximize rear room, as all that weight is going to go to the tongue. I built mine in place using low weight construction material, and still had a problem with tongue weight. This is amplified with a single axle trailer, as the axle is essentially a fulcrum much like a balance scale, unlike the characteristics of a tandem axle trailer which will act to take some of the load.
2. Counter depth. If you make your own, you can adjust your counter depth much shorter than standard kitchen counters. I set mine at 19 inches to increase the floor space in the kitchen. 5 inches doesn't sound like much, but with a 72 inch wide trailer, it makes a noticeable different.
The one drawback is that building the cabinets are not plug and play, but then again, you obvious enjoy the building process, so I doubt this will be a factor. For me, even if there were no money saved, the two issue above are enough to make the decision.
Gunman9 wrote:
I'm thinking about building my own the more I think about it. I can customize it to fit my accessories and to give it a lot more character. I know weight will be an issue since I'll be towing it with a 2009 ford ranger v6. What length kreg screw did you use?
