Tongue set up
Tongue set up
Postby gisclair615 » Mon Apr 27, 2015 4:01 am
Finishing up my 6x12 toy hauler build and need some ideas on how to mount 1 propane bottle and a marine deep cycle battery on tongue. Any ideas and advice? Thanks
gisclair615
Re: Tongue set up
Postby dales133 » Mon Apr 27, 2015 4:16 am
I'm in the thought process of the same thing but including a fridge in the mix.
So far I'm thinking of mounting my battery (s) in the bottom of a box and having a 40 liter fridge on draw slides above it.
When the fridge is slid out you can access the battery from the opersite side and as far as the gas bottles concerned I'm not sure if it will be in the box or external.
That's as far as I've got realy
dales133
Re: Tongue set up
Postby lrrowe » Mon Apr 27, 2015 10:12 am
I have seen many posts here showing how others have mounted their propane tanks, for both TD's and CT's.
Here is one link in Google where if you chose one or another of the choices, there are posts showing several methods.
Hope this helps a little.
https://www.google.com/webhp?sourceid=c ... Atnttt.com
Bob
lrrowe
Images: 439
Re: Tongue set up
Postby desertrat222 » Mon Apr 27, 2015 11:04 am
Here's mine, hold 4 deep cycle bats.
desertrat222
Re: Tongue set up
Postby desertrat222 » Mon Apr 27, 2015 11:08 am
i just welded one of these one. google single LP tank bracket.
desertrat222
Re: Tongue set up
Postby professorkx » Mon Apr 27, 2015 5:45 pm
I've had batteries stolen before, and since I am running a $300 Optima Blue Top dry battery, I had little interest in leaving it exposed. So, while it was $200, I used a very low weight aluminum tongue box. I built a battery box out of wood and mounted it inside the box with straps that hold the battery secure. The tank barely fits inside the box, and because of the lid support, I have to have the propane tank sitting at the right angle so the support misses the metal surrounding the valve. I used wood to make a pocket for the bottom of the propane tank, and since there is only 1/4" clearance on the lid, it can't move around at all.
Out of sight, out of mind...
professorkx
Re: Tongue set up
Postby desertrat222 » Mon Apr 27, 2015 5:52 pm
:thumbsup: :thumbsup: :thumbsup: nice!
desertrat222
Tongue set up
Postby gisclair615 » Tue Apr 28, 2015 3:42 am
Thanks for the ideas. Really nice set ups here. I think I'll just weld up some angle iron and go this route if it fits. I found this image on Google so it's not mine.
gisclair615
Re: Tongue set up
Postby gisclair615 » Thu Apr 30, 2015 1:24 pm
Professorkx, how did you mount the box? Did you use u bolts and bolted it down?
gisclair615
Re: Tongue set up
Postby professorkx » Thu Apr 30, 2015 1:44 pm
gisclair615 wrote:Professorkx, how did you mount the box? Did you use u bolts and bolted it down?
nope. Self taping 1/4 inch screws with fender washers, three on each side screwed into the tongue rails right through the bottom of the box. Added clear silicon to help guard against rust where the screw goes into steel.
professorkx
Re: Tongue set up
Postby gisclair615 » Fri May 01, 2015 5:30 am
Sounds like the way to go! I decided to go with a tongue box and a small propane tank that will fit inside with the battery. Thanks
gisclair615
Re: Tongue set up
Postby Rainier70 » Fri May 01, 2015 4:07 pm
I am late to the party, but this is how we set ours up. On page 8 of our build: viewtopic.php?f=42&t=55219&start=105
We based it off of Glenlivet's mount that he showed in his post here: viewtopic.php?f=42&t=46134&start=0
Rainier70
Images: 244
Re: Tongue set up
Postby lrrowe » Fri May 01, 2015 4:31 pm
I was going to set my tongue up like Cindy shows, but with the spare mounted either higher or the tanks (I will plan on two) on each side. But now I plan on moving my spare more to the back of the CT because of the tongue weight. In the front of the CT itself will be a compact refrigerator and I wanted to avoid too much weight being on the tongue.
Bob
lrrowe
Images: 439
Re: Tongue set up
Postby gisclair615 » Wed May 06, 2015 1:56 am
Nice set ups here. I decided to go with an aluminum box. It should be delivered in a week. This is what I found . I hope it looks good on the tongue. It's 49" x 15" x 15". I will put my propane tank and battery in it. My idea was also extra storage being I'm only in a 6x12.
gisclair615
Re: Tongue set up
Postby Glenlivet » Sun May 10, 2015 2:57 pm
Rainier70 wrote:I am late to the party, but this is how we set ours up. On page 8 of our build: viewtopic.php?f=42&t=55219&start=105
Looks good! Thanks for the homage. :)
Glenlivet
