by boomer » Wed Apr 29, 2015 4:37 pm
I finally bought a Fantastic fan for our Silver Shadow. I cut the hole in the roof and wired every thing in. The roof has a curve to it and it obviously does not sit flush. It did not come with any gaskets. I went to a RV store and bought a roll of putty tape that they recommended. I asked if I should use Butyl tape ( I think I spelled that right ) and they said no that the putty is what I should use. I put a couple of strips of the putty tape where it should go and mounted the fan in place. I figured the tape would fill in the 1/4 inch gap between the roof and the fan. It looks awful and very sloppy. I am going to remove it and take all of the putty off. Are there any reasons why I can't use silicone instead ? I do not think that the putty will leak, it just doesn't look very neat. Thanks for your advice, Ed.
