Well I was trying to make it road worthy for the DAM Gathering. Boo hasn't towed before and she didn't want to make Highway 299 her first towing experience. She is going to drive over one of the days of the event and check out the other Teardrops/Tiny Trailers. So we are going forward and just finish it first before she tows it locally. If anyone still needs a campsite there, I have RV site 37 reserved starting tomorrow (link here:
http://antlersrvpark.com/887181.html ). If I don't hear from anyone by 10am tomorrow, I'll release back to the park. So on with the build.
My son Genarino modded some jeep style flat fenders for the trailer. They were too wide at the bottom so he pie cut them at the corners and welded them back together. They were 34" wide, now they are 27". Then he ground down the weld like it never even happened! They fit perfect.
I put the hatch back on today and temporarily installed Grant's "better than the hurricane hinge".
I then open the hatch to see how good it moves. It's just nice. I then level the hatch to see the clearance. Its pretty close to my calculations (6"4"). My friend and employee Bruce is 6'3", so I had him stand under it. It has about 1 and 1/2 inches above him. Boo is around 4'10".
I then weighed the hatch for the struts. At the very outside it weighs 16.0lbs. On the very inside its 27.5lbs. I probably get 40lb struts (for the pair) for the hatch. More coming soon!
It's a great world if you don't weaken!
Boats float and airplanes fly!
If you boat sinks you can swim!
If you airplane falls you can't fly!
Ken from Eureka Ca.
Boo's Build
viewtopic.php?f=50&t=60867
