Rocky5000100's 7x12 Toy Hauler Build
Re: Rocky5000100's 7x12 Toy Hauler Build
Postby Padilen » Sun Apr 26, 2015 8:48 am
Good eye- the details you can see if your not on a small cellphone screen.
Padilen
Postby Rocky5000100 » Sun Apr 26, 2015 3:31 pm
Thanks. I have since rerouted them through the stress clamps to the right of that hole.
Rocky5000100
Postby Rocky5000100 » Mon Apr 27, 2015 8:11 pm
Hi guys,
I have all the AC hooked up I believe, except ground. That is where I'm a little unclear. Do I need to run a ground from the ground bar in the PD4045 to the frame of the trailer?
I also started running DC til I ran out of wire. The DC will run to a separate ground bar which I purchased, which then connects to the battery negative, right?
Rocky5000100
Postby nunrleft » Mon Apr 27, 2015 11:26 pm
Yes, a/c ground from the grounding buss bar to the frame. d/c ground to the battery negative.
nunrleft
Postby Rocky5000100 » Tue Apr 28, 2015 7:04 am
Perfect, thanks! I may be able to test it today if I can find a power cord.
Rocky5000100
Postby Rocky5000100 » Thu Apr 30, 2015 7:42 am
-Got the wiring mostly done. I just need to run a ground for the AC power. I'm also waiting on my twist lock power cable to show up.
-Sealed up the holes in my battery box
-Used shims to make the lower cabinet flush against the wall,and screwed it to the wall, so the countertop will then be flush against it.
-Installed my Pit Bull trailer restraint. For those who don't know what that is, it's a strapless motorcycle hold-down system. It's pretty much the best thing ever. I've had it for 2 years and I will never use straps again.
Rocky5000100
Postby Rocky5000100 » Sat May 02, 2015 5:48 pm
Guess what guys...I HAVE POWER! WOOOO!!!! And it all worked on the first try too! I didn't have to do anything except plug it in. I tested all the outlets. Also, my DC is working too! I have the lights working and the water pump.
I installed a rocker switch to turn off the water pump. I also sealed the battery box and vented it to the outside.
I feel like a big weight has been lifted off my chest. I was dreading something not working, but I guess months of research on this site really helped!
Charging at 14.39! Perfect!
The wires and the whole inside will be tidied up.
Here is a pic of the strip leds. It isn't as bright as I thought, but it's really simple to add more. I'm going to add 2 more strips to the right and left of this one.
I also got the countertop cut today and test fit it. I haven't screwed it in yet so I can easily work on the plumbing.
Got some of the plumbing done today:
Rocky5000100
Postby Gunman9 » Sat May 02, 2015 7:30 pm
Rocky5000100 wrote:Guess what guys...I HAVE POWER! WOOOO!!!! And it all worked on the first try too! I didn't have to do anything except plug it in. I tested all the outlets. Also, my DC is working too! I have the lights working and the water pump.
Where did you get your plumbing fittings?
Gunman9
Postby Rocky5000100 » Sat May 02, 2015 7:52 pm
Menards plumbing section. They are plastic PEX fittings. 1/2" thread to 1/2" tube. Here's a pic, the one in the middle.
Rocky5000100
Postby Gunman9 » Sat May 02, 2015 7:53 pm
Thanks! I wish they had a menards in VA. I'm originally from Ohio and I know menards always has better deals and prices then lowes or homedepot.
Gunman9
Postby nunrleft » Sat May 02, 2015 8:37 pm
Nice job!
nunrleft
Postby Rocky5000100 » Sun May 03, 2015 5:38 pm
Got the sink in today and finished up the plumbing! I went with the straight pvc pipe into the tank because it would have been very hard to find a flexible water drain solution. The cabinet is going to get a nice thorough vacuuming tomorrow.
Rocky5000100
Postby nunrleft » Sun May 03, 2015 5:50 pm
I do see one issue with your battery vent. Sulfuric acid fumes are heavier than air so your vent should be at the bottom of the battery box and vent down.
nunrleft
Postby bdosborn » Sun May 03, 2015 5:56 pm
No he's got it right. You're trying to vent the explosive hydrogen gas, which is lighter than air.
Images: 806
Postby lrrowe » Sun May 03, 2015 5:59 pm
You could also use this inline valve for your sink.
http://www.amazon.com/dp/B00NLMPLDU/ref ... 9FOKMCIN4P
Bob
lrrowe
Images: 439
Users browsing this forum: Google [Bot] and 1 guest
