wtcreaux wrote:If I'm seeing the picture correctly, you used 2 opposing pieces of J-trim - 1 on wall, 1 on ceiling??
Spotman wrote:Pop in the microwave and off you go, oh bed too. Looking good.
rebapuck wrote:Show some pictures of those buttonhole curtains. That's ingenious.
professorkx wrote:This is what I am planning to use if I ever get around to installing 120 volt heat, as I want it to cycle based upon inside temperature.
http://www.homedepot.com/p/Cadet-Double ... /202502063
This simply cuts the input voltage to the unit. 22 amp rated, so plenty of amp capacity to anything we would use in the trailer...
