"What was the hardest part of your build?" thread.
Postby tony.latham » Tue May 05, 2015 2:30 pm
Sometimes building a teardrop can feel like you're climbing a mountain while wearing lead boots and a blind fold. 8)
In looking back, what was a tough part? Photographs if ya got 'em. :thinking: :pictures: :thinking:
Tony :beer:
Re: "What was the hardest part of your build?" thread.
Postby dogscats » Tue May 05, 2015 5:04 pm
So far planing.But with all the input. I believe I am over that hump. Now just painting by numbers. I have it down to 10 to 15 minute jobs
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby daveesl77 » Tue May 05, 2015 5:34 pm
I would have to say the forcing myself to stop every now and then and not work on the camper for a day or two, just to reset the brain and give the old body a break.
This has become one of the most enjoyable things I have done in a very, very long time. I love watching the ideas come together. It isn't all smooth sailing, as there have been a few rough rides and will be more, but for the most part it has just been fun!
This website has been a life saver. The people are fantastic! They don't mind giving their mind either and I appreciate that.
dave
daveesl77
Images: 273
Postby Dalorin » Wed May 06, 2015 6:49 am
So far the hardest part for me is trepidation. Just a general fear that I'll mess it up. I'm getting past it by telling myself that I'm basically a kid building a tree house. Somehow that makes things easier. Physically this has been difficult for me because I'm not really built for manual labor. Moving large pieces of plywood back and forth was extremely difficult. My body is more built for endurance than strength. So I've pretty much sworn off building another camper till my boys are old enough to help.
Dalorin
Postby bobhenry » Wed May 06, 2015 7:06 am
Installing a queen size pillow top mattress in the tiny trailer.
Here is my secret in this pic..........Image
Note the front of the lexan roof is not pulled down into place yet. I had to wrestle the mattress thru the open slot under the roofing and drag it into place. I guess if it ever needs replacing it will be reverse engineered the same way :thinking:
Postby noseoil » Wed May 06, 2015 7:46 am
With a full time job, for me it's having enough time to keep going on the build. I have to chop things into shorter tasks than I would like, but there is an "up" side to this. It gives me more time to think about the build and map out better ideas while I'm working. The planning is going very well, because I have limited time to do the actual building, so I guess it's a fair trade.
All in all, I'm enjoying this build more than I have anything else in years, and am looking forward to actually being able to use it for trips when I'm finished, if that ever happens. Glad I set a schedule of 2 years for completion, I'm still on schedule!
137905
noseoil
Images: 670
Postby aggie79 » Wed May 06, 2015 7:50 am
noseoil wrote:With a full time job, for me it's having enough time to keep going on the build. I have to chop things into shorter tasks than I would like, but there is an "up" side to this. It gives me more time to think about the build and map out better ideas while I'm working. The planning is going very well, because I have limited time to do the actual building, so I guess it's a fair trade.
+1 (My two year build turned into a three year build. Of course, that's the 95% complete stage. I still haven't finished the other 5%.)
Postby Vedette » Thu May 07, 2015 1:15 pm
Posting Pictures in my Build Journal? :R
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby kitecop » Fri May 08, 2015 9:00 pm
Gluing the inner and outter skins of my sandwich walls and getting it to stick well. Had to go around and inject and clamp a lot of areas after the initial gluing. I wish i had one of those big 1" thick solid steel plates they use on roadways durring construction to set ontop of it while the glue set.
kitecop
Images: 14
Postby pchast » Fri May 08, 2015 9:53 pm
Designing. Then, restraining my spending on neat stuff.
pchast
Images: 97
Postby GPW » Mon May 11, 2015 8:40 am
Convincing everyone else it would actually Work !!! :roll:
Postby mrwall1 » Tue May 12, 2015 12:37 am
For me it was the radius on the curves.... and then getting the plywood to work! Main reason I didn't curve the back....
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Postby dales133 » Tue May 12, 2015 4:06 am
Frustration waiting on parts or waiting until you can aford them!
And Yea. ..posting pics
dales133
Postby Shadow Catcher » Tue May 12, 2015 8:56 am
Realizing it will likely never be "finished". OK it is finished but there is always room for "improvements", not to mention fixing mistakes.
Postby Kharn » Tue May 12, 2015 7:37 pm
Putting the RV doors on. They shipped with a bad batch of stainless screws, so I was twisting the heads off with my battery drill even at low RPMs and had to remove the doors several times to remove the broken screws.
Found out to use plain steel screws instead, all was well.
Kharn
Users browsing this forum: Google [Bot], TimC and 1 guest
