KCStudly wrote:How do you plan to stabilize the angle steel? Will there be some kind of end plate or gusset plates joining them? Just saying, angle iron can be twisty if not laterally supported.
angib wrote:KCStudly wrote:How do you plan to stabilize the angle steel? Will there be some kind of end plate or gusset plates joining them? Just saying, angle iron can be twisty if not laterally supported.
Bolting the half-axle mounts to the angle iron will stabilise it fully - the mount will be a substantial casting.
Aligning half-axles seems to be a concern in the US and I think that is because they aren't common. It really isn't rocket science and does not need to be done with the same precision as car/truck wheel alignment. If you plan to do 20,000 miles of towing a year, there might be a benefit to aligning the half-axles carefully to minimise tire wear, but for normal trailers that isn't necessary.
Mary C wrote:I want to suggest that you make a box put canvas on the outside and inside with TBII let it dry and paint it with a couple of coats of paint , then ask yourself why wood on the inside?.if you wantultra light why the wood? You can paint it with a faux wood if you just like the wood look. I like your idea and design.
Mary C.
angib wrote:Bolting the half-axle mounts to the angle iron will stabilise it fully
angib wrote:But it may be that RW has left out the angle irons along the bottom of each sidewall, or just not drawn them.
