Al in PA wrote:Len, I've read your tutorial on creating aluminum siding using an aluminum brake - excellent. Also, I've studied the pictures in your last post. I cannot figure out how you got a continuous 13' run of siding from an aluminum brake when they usually come in 8.5' or 10' lengths. Would you share your technique for creating 13' runs of siding or explain how you overlap shorter runs making them invisible and water tight? Thanks.
LandCommander wrote:Very impressive! What is the material you are using inside on the ceiling?
