MtnDon wrote:Well that changes things. Have you looked at linear actuators? We used one with a 30" stroke for a TV lift a couple years ago. You might be able to use one at each end with guide tracks in the corners.
KCStudly wrote:The trouble with an air system is keeping everything synchronized. If one corner has less weight or friction than the others it will go up first racking the roof and potentially binding.
I would prefer a cable pulley system like the OEM's use, and if you want to have it be power operated you could look into a small 12v ATV or boat winch. Using small cable and pulleys, this kind of system can be very compact, and once adjusted will always pull all four corner equally.
dales133 wrote:The other downfall with air is you need a compressor, tank plus all the associated plumbing involved .alot of cost and work for something a simpler solution and do just as well
