PVC framing under Foam ...
Postby GPW » Sun May 05, 2013 9:02 am
Had a thought ... :roll: What about a PVC pipe frame under the foam and canvas ... :thinking: Nothing to Rot , protected from UV exposure, and like the foam , Extremely flexible without breaking ... PVC is cheap, easy to cut and bend to most any shape we want ... and there is a selection of end caps , Tees , 90’s , etc.
Wouldn’t need much to glue it to the foam , the glue only as strong as the foam it’s glued to ... Or, the foam could be channeled slightly (hot wire) to receive the PVC pipe for a more secure fit ... and seemingly enabling the parts to be made as “panel” or modules to be assembled later ... The skin holding it all together !!!
And then there’s that square PVC fencepost available ... wonder what we could do with that ... and a saw ... :thinking:
Re: PVC framing under Foam ...
Postby GPW » Sun May 05, 2013 12:44 pm
And just to add to that thought , an oversimplified drawing as an explanation ... and the idea that you could also use the PVC as wiring runs too ... Multitasking :thinking:
Postby GPW » Mon May 06, 2013 6:37 am
No comments eh ? Consider this .... Nothing to Rot !!! :thinking:
Postby KCStudly » Mon May 06, 2013 11:48 pm
My thought is that the std. ftg's would be a big restriction to organic shapes. Also, PVC can be brittle in cold climates.
Could work, just not for me.
Postby GPW » Tue May 07, 2013 6:02 am
Hmmm? perhaps ? The fittings were just one example of what “could” be done ^ .... For The COLD regions , use the gray PVC ... ;)
Postby Werdahekrwe » Thu May 21, 2015 10:04 pm
Since I am in the planning stage of a pop-up foamie, and who plumbed two homes w PVC, it looks VERY interesting. Gonna keep it as a possibility. :D
Always remember: You can't fly with eagles if all you hang around with are turkeys.
Werdahekrwe
Postby Werdahekrwe » Thu May 21, 2015 10:05 pm
Duplicte post. Sorry
Werdahekrwe
Postby Fred Trout » Thu May 21, 2015 10:45 pm
The trouble with pvc pipe is when round meets square. It's pretty hard to actually connect the pvc to the required structure it is intended to support without too much fiddling.
Fred Trout
Postby Mary C » Thu May 21, 2015 11:08 pm
Have you forgotten about the DUCK tear ?? viewtopic.php?f=55&t=56828
Mary C
Images: 473
Postby GPW » Fri May 22, 2015 6:50 am
Two years later , I still think this is a good idea ... PVC plumbing pipe has certainly proved itself durable around here with all the Bow making and shooting that went on . (archery bow ) :thumbsup: And , since we learned to easily heat bend it , the sky’s the limit ... :thinking:
Postby Mary C » Fri May 22, 2015 10:19 am
I too, think it is a good idea When I come down maybe we can flatten a three foot piece leaving about 2 inches on each end.
Mary C.
Mary C
Images: 473
Postby GPW » Fri May 22, 2015 10:43 am
... or flatten just the ends ... :thinking:
Postby Fred Trout » Fri May 22, 2015 11:18 am
Too bad it does not come in a square shape. Then we would be in biz for sure and I certainly like the ease of working with PVC, great stuff.
Fred Trout
Postby GPW » Fri May 22, 2015 12:39 pm
Oh , but it does !!! :D
Postby Fred Trout » Fri May 22, 2015 3:08 pm
That's interesting. You have the advantage of me; easier to buy weird stuff in a major metro area with large petro-chemical plants nearby than around here in the boonies. Our advantage is miles and miles of nobody !!
I did see some on Amazon but limited in length due to shipping restrictions.
Fred Trout
