by ipy » Fri May 15, 2015 2:13 pm
Once I finished lower part of the caravan, I started working on its roof. Decided to cover it with PVC panels, because they are lightweight, yet strong and water-proof. Panels are quite wide but still there were connections between them on a flat surface of the roof. In order to give this connections more water resistance, I filled whole lengths with a glue-sealant.
Applied a bit too much of this glue and that caused very narrow gaps between flat surfaces of panels. They were still water-tight but it did not look good to my eyes and I supposed it would be even worse when dirt would collect there.
So after I sealed all connections between PCV panels on a whole roof and a front of the caravan, I added a layer of polycarbonate panels, with chambers running perpendicularly comparing to PVC panels. First I applied every second piece of polycarbonate, then the rest. Finally I sealed panels with another layer of a sealant.
Now the surface is nice and flat but because of the fact that polucarbonate is transparent, I need to cover the whole thing with the last layer- self-adhesive foil, white in colour.
- Attachments
- SealedPVCpanels.jpg (36.1 KiB) Viewed 2342 times
- PVConTheRoof.jpg (54.37 KiB) Viewed 2342 times
- PolycarbonatePanels.jpg (56.24 KiB) Viewed 2342 times
