Installed the light cover and test the wires to confirm proper polarity and operation. All is good.
ghcoe wrote:Yes, cuts like butterJust have to keep the wire fairly short, too long and it will not cut. Just take your time. Best part is that you have no foam dust to deal with.
ghcoe wrote:I just order in my LED lighting today. I got (10) 20" interior lights, (4) yellow clearance lights, (4) red clearance lights, (6) white porch lights, (2) tail lights and (2) license plate lights. A grand total of $73.62.
lrrowe wrote:George, I have tried reviewing over 100 pages with AliExpress and I cannot find these particular marker lamps with the threaded shafts. You wouldn't have the direct link to them anymore would you?
Thanks,
Fred Trout wrote:George, a few questions if that's ok.
Do you still plan to use carriage bolts through the existing door frame assembly as you originally intended or will the canvas hold all of it well enough ? I assume the canvas will not wrap all the way across the door edge to the far side but will stop at some point on the metal flashing inside edge.
How will you deal with the corner bead edge sticking into the doorway opening ? Is it too sharp an edge to leave raw ? Or will the rubber gasket cover it ?
I am trying to decide if I should embed wood in my door installation; it's hard to see how you plan to install the door lock mechanism without that.
Thanks for all your posts; they have been very helpful.
