DI box
DI box
Postby Tabitha » Wed May 27, 2015 2:11 am
Has anyone needed to install a DI box to reduce hum in speakers? If so how the heck to they connect........ HELP!!!!! :?
Someday, we will learn to take living in stride. Sometime, we will learn to pay less attention to the imagined and stop fussing about things we had nothing to do with in the past - and cannot change significantly in the future. Very soon, we will sit together in the sun a whole day and just be happy that we can sit together in the sun all day and just be happy.
___ Cherokee Author Unknown
Tabitha
Images: 82
Re: DI box
Postby GPW » Wed May 27, 2015 6:01 am
Tab' , being a musician , a DI box is usually used to pick off a line level signal from a speaker output ....Not to reduce Hum ...  Unless you have something different . Hum is usually the result of a faulty power supply ... :thinking: What are you using that makes Hum ?
Re: DI box
Postby noseoil » Wed May 27, 2015 7:43 am
Is it a regular automotive CD/radio deck with the hum from the speakers? Is it there all the time, or is there some other electrical item on your system which makes this hum? Is it a "60 cycle" hum? The inverter comes to mind as was already mentioned, but other electrical appliances can contribute to it if they're on at the same time.
137905
noseoil
Images: 670
Re: DI box
Postby pchast » Wed May 27, 2015 10:03 pm
I seem to remember Auto stores used to sell a capacitor/coil pair that could be used to
clean up the power to the radio.... before spark plug wires went all to carbon instead of copper.
:thinking:
pchast
Images: 97
Re: DI box
Postby Tabitha » Wed May 27, 2015 10:15 pm
We run an XM radio hooked into a 12 volt amp with speakers. We didn't have the hum until I added the last few usb ports in the cabin now I have a hum.
Tabitha
Images: 82
Re: DI box
Postby GPW » Thu May 28, 2015 5:04 am
Maybe it’s your wiring? Try disconnecting the new USB ports (temporarily) Sounds like your wiring is making a “ground loop” ...
Re: DI box
Postby noseoil » Thu May 28, 2015 7:01 am
Tabitha, I appreciate your post on this problem. The USB ports I've added will be switched, hopefully it will help to isolate the problem in the future. If it turns out to be the USB's which are causing the problem, you might consider the use of a switch to keep them cold, unless they're actually in charging mode with something plugged in. Here's what I did, because I didn't want to have the blue LED's on all the time while sleeping.
I'm wondering if I will have the same issue with my CD deck, once I finally get to that point in the build. Hmmm........
137905
noseoil
Images: 670
Re: DI box
Postby Greg M » Thu May 28, 2015 11:21 pm
A lot of USB converters will cause hum like that. It's the switching power supply that's built into them. A power line filter on the car stereo's 12 volt lines will probably clean it up.
Greg M
*Geek Extraordinaire
Images: 85
Re: DI box
Postby Greg M » Thu May 28, 2015 11:31 pm
Greg M
Images: 85
Re: DI box
Postby Shadow Catcher » Fri May 29, 2015 2:44 pm
We have an XM receiver that is fed through a car stereo. I have one automotive style power point and a Belkin USB adapter which can power/charge the cell phones or iPad. Normally when we are on 120AC we just use the wall warts there are four 120 outlets at the head of the bed.
100379
Re: DI box
Postby Tabitha » Thu Jun 04, 2015 4:19 pm
Thank you everyone I'm thinking it is a ground loop that's why I had questions about the DI box.
Thank you Greg I think I'm going to try the box you recommended, I'll keep you posted.
Tabitha
Images: 82
Users browsing this forum: Google [Bot] and 0 guests
