by KCStudly » Thu May 28, 2015 2:21 pm
For a leaf spring axle, measure the distance between the frame and the closest point where the axle (in a "spring under" configuration) or spring pack (in a "spring over" configuration) will hit. Then add about an inch to 1-1/2 inches for tire deflection and axle flex or tilt (i.e. one wheel lifting while the other drops out), more if you are running bump stops that may compress some.
Same for side wall clearance, about 1 to 1-1/2 inches is a good minimum to shoot for, IMO.
Some may argue that a trailer is a tripod and you can disregard axle tilt, but I would argue that if, at speed, you hit a pothole on one side and simultaneously hit a bump on the other, the kinetic energy of the mass of the cabin will tend to keep the trailer moving level while the axle reacts underneath it. Otherwise, why have springs at all? And if you don't believe that this happens regularly in normal driving, then you have never driven in New England (otherwise known as pothole and frost heave country).
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
