King Jack Antenna
Re: King Jack Antenna
Postby jjvw » Tue Jun 02, 2015 9:08 pm
mine was only the king jack head for $35, that was designed for replacing the wing ant head on your crank up mast. You must have the complete unit. My lead wire goes thru the window. they make a 6" flat wire adapter that the window can close on.
jjvw
Images: 23
Postby Gunman9 » Tue Jun 02, 2015 9:28 pm
jjvw wrote:mine was only the king jack head for $35, that was designed for replacing the wing ant head on your crank up mast. You must have the complete unit. My lead wire goes thru the window. they make a 6" flat wire adapter that the window can close on.
Ya I have the complete unit. I think I'm just gonna install it through the ceiling and be done with it. I have lapping and seal putty so I should be good.
Gunman9
