CHMLEON wrote:After reading a bunch of horror stories about single axle trailers swaying and losing control, I want to get some feedback from those that have finished their conversations and have put some miles on their rig. I am looking to build a rig that is 3500# gross vehicle weight or less.
Some questions I have about your conversion:
* Size?
* Overall Weight?
* Tongue Weight?
* Single or Tandem?
* Why did you choose Single or Tandem?
* Brakes or No Brakes?
* About how many highway miles have logged?
* Any towing problems?
* Any regrets to your cargo trailer choice?
Thank you for your help and feedback.
-7x12. I thought this was a good compromise between a 6x12 and 7x14. I also opted for the 6.5ft interior height.
-Current weight is about 2950lbs loaded. It was about 1900-2000 empty.
-Tongue is about 400lbs (13%).
-Single axle
-I chose single axle because I didn't want the extra weight of the second axle. My max tow on my 2002 4runner is 5000lbs, so a 7000lb trailer was unnecessary. It tows very nicely. No problems with wind or stability. I was thinking when I bought it that I'd need a Weight Distribution and sway controller hitch, but so far I have had no need.
-BRAKES. I can't imagine towing without them. I'm so glad I got them. Most 7x12 single axles come with them. It makes the trailer so stable under braking, and puts less wear on my tow vehicle, which has subpar brakes as it is (most people upgrade the 4runner to Tundra calipers/rotors for better braking). I went with a Prodigy P2 brake controller, and the different settings are great. I like turning on the brake boost to B1, so when I brake, the trailer brakes activate harder sooner. It translates to good control while braking.
-About 500 highway miles.
-No towing problems, but I'm definitely not setting any land speed records. I can do 65mph at 2900rpm, and maintain that for most places. O/D is turned off. I get 10-12 MPG. My transmission temperatures are good, but I will be adding a transmission cooler soon. A more powerful tow vehicle would be nice, but not necessary.
-Not really, but I have thought about upgrading to a 5000lb axle. It wouldn't be too much, and it would allow me to carry another two motorcycles if necessary.
