Small 12 volt battery for TD
Anything electric, AC or DC
Postby Whuttitiz » Sat Jun 13, 2015 2:13 pm
We saw somewhere on the forums about a small 12 volt battery that could be used for the TD. It was not a wet cell battery and had no lead in it. Does anyone have any information on this?
Thanks,
Denny
Whuttitiz
Re: Small 12 volt battery for TD
Postby daveesl77 » Sat Jun 13, 2015 2:40 pm
What kinds of things do you want to run? That determines the size battery you need. Don't just think of the bare minimum but also what you'd like to have.
dave
daveesl77
Images: 273
Postby Whuttitiz » Sat Jun 13, 2015 3:08 pm
Not much in the way of lighting as they are all led. We would like to run our fantastic fan roof vent through the night though. It takes 3 amps to run it. We found what we think might work in the Braille M7 lithium battery. It's only 2.2 pounds. Just trying our best to cut down on weight.
Whuttitiz
Postby H.A. » Sat Jun 13, 2015 11:40 pm
H.A.
Postby GuitarPhotog » Sun Jun 14, 2015 1:38 am
3 amps times 8 hours = 24 AH. It all starts there. Add an amp hour or two to account for the LED lights, so maybe you need to provide 30 AH. With lead acid you shouldn't discharge below 50%, so if you were designing for a LA battery, you would need a 60 AH battery and the means to replace 30 AH
daily. That means running a 3A charger 10 hours every day.
Battery basics. The capacity calcs still apply with Lithium, but I don't know about discharge limits, or availability of smart lithium battery chargers that don't cost an arm and a leg.
GuitarPhotog
Images: 55
Postby pohukai » Sun Jun 14, 2015 11:58 am
I use 12v drill batteries (3amp/hr). I could connect 4 in series for a big weekend, but 1 has been more than sufficient for the interior/porch lights and the computer fans for ventilation.
For my camping purposes, this has worked out excellent.
I can also connect a shore line to an old computer power supply and use the 12V rails for unlimited 12v power. I've NEVER used this when camping.
pohukai
Images: 9
Postby Whuttitiz » Sun Jun 14, 2015 12:41 pm
Thank you all for the input. Still a learning curve for us!
Whuttitiz
Postby GuitarPhotog » Mon Jun 15, 2015 12:02 am
pohukai wrote:I use 12v drill batteries (3amp/hr). I could connect 4 in series for a big weekend, but 1 has been more than sufficient for the interior/porch lights and the computer fans for ventilation.
No, you need to connect them in parallel. Connecting four 12 V batteries in series will produce 48 V, enough to burn out lots of things. Four 3 AH batteries in parallel is equal to one 12 AH battery.
Don't use a computer power supply to charge a battery, the voltage is too low and you will ruin your battery quickly.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby len19070 » Mon Jun 15, 2015 1:21 am
I used one of these in a trailer years ago.
Hooked it up to a trickle Charger in the trailer so when I had electricity it would run all the time no matter what.
But without electricity All it did was 2 lights for 3-4 days and that was it. Battery lasted 2 years.
http://www.ebay.com/itm/CASIL-12V-7AH-C ... 43d73c7ca4
Not the best set up but it did work.
Happy Trails
Len
len19070
Images: 24
Postby pohukai » Mon Jun 15, 2015 9:05 am
Thanks... You're right and I do connect them in parallel. I completely disconnect the batteries if I'm using the power supply and do not charge the batteries with it.
pohukai
Images: 9
Return to Electrical Secrets
