by cpowell243 » Fri Jun 12, 2015 9:46 am
I am traveling and away from the BEULA project for a few days - physcaiily but not mentally, as I'm sure you all can understand.
When I return my plan is to glue the walls and door frames to the pillars, then temporarily attach walls to the nose to get an accurate read on where the wheel wells need to be cut out of the walls. After cutting the wheel wells I can then re-attach walls permanently to the nose and begin covering with canvas (I think).
Before going further,I am wrestling with the wall attachment at the wheels wells. Glen and Foamstream avoided this problem via smaller wheels and higher clearance, but I have about 10" of fender above the floor.
My metal fenders have metal plate welded down to the frame on the inside of the fender to create a weather-proof seal. If I can attach the wall to the top of the fender I can cover the portion of the metal fender that is exposed to the interior. Hope that makes sense. Challenge is then to create a weather-tight seal where the fender meets the wall. Would it work to fold the canvas under the foam, then glue the wall directly to the metal fender using construction adhesive (or something better)? Would it work better to glue 1X2 to the bottom of the 2" polystyrene than canvas and glue to the fender? Other options?
Th - Ch
