thobbs wrote:I'm on a steep learning curve, so any advice is great. I'm building a slightly modified Cubby. I didn't cut it down so it is 8 ft still. I'm doing shelves instead of cabinets to cut down on weight. I didn't move the chassis.
I just finished the wood deck for it. Here are my questions.
1. Where should I put the spare tire? I have a large cooler and stove I'm putting in the galley (see album) which when loaded will weigh a lot, so I'm concerned about the amount of weight in the tail. Where on the underside should I mount the spare tire for best weight distribution?
2. What are fender washers and why and how do I use them for the underside insulation? Any pics anyone!
3. It says to glue in the insulation after putting on the asphalt emulsion. Will the glue stick to the sticky asphalt?
Thanks, I'll try to post some pics later today or tomarrow. I'm moving my build to the new house construction site today. Should be fun! All the good tools are there.
