by ipy » Fri Jul 03, 2015 1:51 pm
Everything is nearly ready for a final part: joining roof panels with walls. Old, damaged plywood is replaced with a new one, rear wall is insulated and have both layers of plywood, wall between child bedroom and main room is insulated as well, walls in child bedroom are finally painted. All parts of ceilling are also painted. I cut out a little bigger entrance to a child bedroom as well as made an opening for a storage compartment, accessible from child bedroom.
On lower edges of my caravan box I applied self-adhesive, round "legs" made from teflon, to keep a small distance between wall and a trailer board. On sides of walls there are metal elements that will hold boards and ensure walls will not bend. SImilar element will be installed inside, also.
I decided to use a polyurethane varnish for newly built external parts. It is designed for painting garden chairs, tables, fences and wooden finishes of buildings. UV protected, water and weather proof, allowing walls to "breathe" and long- lasting. I hope this is a good solution...
Now I wait until weather forecast will say there will be no rain for at least two days...
- Attachments
- WallSupports.jpg (40.09 KiB) Viewed 1660 times
- NewParts.jpg (41 KiB) Viewed 1660 times
- BedroomWall2.jpg (91.07 KiB) Viewed 1660 times
