KCStudly wrote:The reason the "PMF" (poor mans fiberglass, otherwise known as canvas and glue) is highly recommended is that it binds the wood fibers together with fibers running in both directions. Over a bent plywood, the outer fibers will not be prevented from splitting simply by painting over them. It may look good for a while, but with exposure to weather, or even just time in the stressed (bent) state the wood will likely start to split between fibers. This will create openings in the paint for water to intrude, then all bets are off. I had little miniature splits in my front radius ceiling ply even as I was installing it.
With the bedsheets or canvas glued on, the wood fibers are strengthened and are much less likely to split, giving a stable base for paint. One member was able to get used bed sheets free just by asking at his local hospital, or you could try a hotel/motel, or B&B. I got several king size top sheets at a yard sale just by asking. Thrown in with some other items for $5. They were going to throw them out because they didn't think anyone would be interested in someones old bed sheets. Truth be told they were in fine shape, so I don't know why they would have thrown them out.
KCStudly wrote:Still, if you plan to fill in the joins they are a potential failure point where cracks can begin. 4 or 6 inch wide strips of fabric glued over these joints, or better yet, fabric panels lapping over each other by a couple of inches from facet.
Really the only cost adder is some glue, and that is not much on the grand scheme of success or failure.
Do you plan to store her inside or out?
noseoil wrote:Neil, good point made about the cloth & overlapping seams. Over time, the edges & joints will begin to work & open, unless they are wrapped first. I think of it like drywall seams. Unless there's some type of mesh or membrane covering it, cracks will form, water will get in and things will beak down.....
