Smooth canvas finish...
Re: Smooth canvas finish...
Postby Fred Trout » Thu Jul 09, 2015 6:13 pm
Gripper beading a TB II layer on top sounds about right. It's surface is real slick and the paint itself is pretty resistant to sanding. George (ghcoe) had the great idea of putting Gripper on raw foam as an indicator of when you are sanding down into the foam. But I will now sand & perforate (h/t rowerwet) all foam surfaces to avoid bubbles. Only takes a couple of minutes.
You really should sand all slick surfaces before you put anything on top anyway and I have also gotten into the habit of cleaning slick surfaces like flashing with alcohol to remove any oils contamination.
Fred Trout
Postby mikeschn » Thu Jul 09, 2015 6:23 pm
Well, here's the final results. They all look good, and I think any one of the finishes would do well to protect the foam and wood underneath...
Gripper on the left, garage floor paint on the right
TBII on the left, gripper on the right.
Postby Fred Trout » Thu Jul 09, 2015 6:24 pm
Jack, your garage needs more dirt and some interesting bugs running around to distract you -- like mine :R :R :R
You have these around there:
Mike, looks like the Gripper on top fills the fabric weave the most of all those but hard to be sure with those pix. Which looks best filled to you ?
Fred Trout
Postby mikeschn » Thu Jul 09, 2015 6:38 pm
The garage floor paint looked the best to me. But
I'm going to give it another coat, and try rolling it on.
Postby Fred Trout » Thu Jul 09, 2015 8:28 pm
Thanks.
Interesting ... will look forward to that.
Fred Trout
Postby Jack Olsen » Thu Jul 09, 2015 10:54 pm
KCStudly wrote:OT Warning: Don't go look at any of that stuff Jack Olsen has been doing with his 12 Gauge Garage and Black Beauty II 911 Porsche track car projects. You will spend hours and hours there, like I have.
Nice work Jack, and very well presented. :thumbsup: :applause:
We now return to your regularly scheduled programming.
Fred Trout wrote:Jack, your garage needs more dirt and some interesting bugs running around to distract you -- like mine :R :R :R
Thanks, guys. The garage is all cleaned up for the pictures. But most of the time it's got a lot more going on in it.
That bug looks like you could put a collar on it and make it a pet. :)
mikeschn wrote:The garage floor paint looked the best to me. But
Thanks for doing this testing. Is the garage floor paint water based?
Jack Olsen
Postby Mary C » Thu Jul 09, 2015 11:42 pm
The next question is which one sands to a smooth finish. I know gripper is a primer and is formulated to be sanded and to have a top coat of paint. So far it holds up really well. so let us know your results.
Mike are you going to CRA?
Mary C
Mary C
Images: 473
Postby mikeschn » Thu Jul 09, 2015 11:59 pm
Jack Olsen wrote:Thanks for doing this testing. Is the garage floor paint water based?
It's the Behr 1 part epoxy, yes!
BEHR PREMIUM® 1-Part Epoxy Concrete & Garage Floor Paint
Beautify and protect your home's interior and exterior concrete surfaces with BEHR PREMIUM 1-Part Epoxy Concrete and Garage Floor Paint. This water-based paint can protect against hot-tire pick-up, automotive fluids and most household chemicals. This epoxy paint will provide a beautiful protective finish on driveways, garage floors, pool decks, walkways and interior concrete surfaces.
Postby dales133 » Fri Jul 10, 2015 2:27 am
That bug looks like a Weta. ..thought they only had them in NZ
dales133
Postby felixx » Fri Jul 10, 2015 2:54 am
NZ Giant Weta (not photoshopped)
felixx
Images: 22
Postby rowerwet » Fri Jul 10, 2015 5:10 am
TB II is best for glueing the fabric on after that paint works best. One guy building foam boats thickens his water based paint with cabosil (micro balloons) to make smooth boaty finishes over fiberglass cloth.
Search YouTube for dave Lucas foam kayak.
He claims one coat smoothing.
The TB II foam to fabric bond being best for repairability using heat.
rowerwet
Images: 521
Postby GPW » Fri Jul 10, 2015 5:34 am
Gentlemen, take care using micro balloons ... It was reported the ultra light substance floats through the air and is not good to inhale ... Just opening the jar send particles into the air ...
Postby Fred Trout » Fri Jul 10, 2015 10:59 am
GPW wrote:Gentlemen, take care using micro balloons ... It was reported the ultra light substance floats through the air and is not good to inhale ... Just opening the jar send particles into the air ...
Aww shucks, doing a build generates all kinds of dust, GPW, pretty hard to avoid. I wear a mask when doing this but ...
Dust 1.jpg (237.04 KiB) Viewed 1036 times
Dust 2.jpg (155.71 KiB) Viewed 1036 times
Fred Trout
Postby mikeschn » Mon Jul 13, 2015 4:40 am
I sanded the 3 samples... They all sanded nice and smooth. The dark gray shows best what happens to the paint after you've sanded. It certainly needs another coat!
Postby GPW » Tue Jul 14, 2015 9:50 am
Mike , unfortunately , the only old school way we know to a really smooth finish is by filling the imperfections and block-sanding with progressively lighter grits till you get it as smooth as you want ... Much as you’d finish a car, furniture, or even a wall ... :thinking:
Users browsing this forum: DrAlvarez and 16 guests
