So if I'm getting this - to remove a seam brush glue on either side and cut the seam out, then use the smaller pieces with the joining method you describe (overlap and cut through both). Based on your description no real advantage to using one continuous sheet as the places where two sheets meet cannot be detected.
cpowell243 wrote:But did you really have to put in that "every single bump, scratch, joint divot & hole" bit? Using a wood pillar and gluing 1" to rabbited 2" is not the best for achieving a perfectly flat surface. Probably best that I'm starting with interior that only we will be looking at.. and that my eyesight is poor. Will be counting on others to be polite when they comment on it.
cpowell243 wrote:Just finished gluing canvas to the right side interior wall. Canvas and TBII covered minor divots pretty well. I used Fred's technique of overlapping canvas pieces and cutting down the middle of the overlap, then reglued and ironed the fabric down. Minor spackling will be needed in a few places and a few wrinkles, but paint should help cover and overall I'm happy with result. I'm more about make it work and last vs. cosmetics. This weekend I cover the left interior and paint both sides, then glue the nose in place and attach the two walls to the nose. Will document and post pics Sunday night, hopefully.
Big relief that my first attempt at canvas turned out OK.
Ch
