Bread-loaf build thread
Re: Bread-loaf build thread
Postby Fred Trout » Mon Jul 13, 2015 7:29 pm
Thanks, Mike.
OK, thought I would show how I deal with two different 'glues' on this side canvas application. Gripper for flashing & canvas, TB II for foam & canvas.
- First I stick push pins on the upper edge foam, roll back the canvas, exposing the alcohol cleaned flashing
- apply the Gripper onto the flashing instead of TB II .
- Flip the canvas down the side & position it
- Massage the canvas onto the wet Gripper paint,
- Wait a while for the Gripper to dry.
Then I apply the TB II as usual, do the edges, trim, fold over, etc., as usual.
OK.... time to go put the TB II on - wish me luck !!
EDIT: Bah, thunderstorm stole my light - to be continued tomorrow...
Pix:
The flashing problem exposed !!!!!
Canvas right 1.jpg (153.99 KiB) Viewed 22841 times
Pinning
Canvas right 2.jpg (124.1 KiB) Viewed 22841 times
Canvas massaged into Gripper coated flashing
Canvas right 3.jpg (94.44 KiB) Viewed 22841 times
Fred Trout
Postby GPW » Tue Jul 14, 2015 9:39 am
Hey now !!! Looking Good !!! :thumbsup: 8) :dancing
Postby Fred Trout » Tue Jul 14, 2015 2:13 pm
Thanks, GPW, making progress this week.
Now I have the rest of the right side done including all trimming, edges, tucking, bobbing & weaving :R :R OK, I do have some more trim work to do with the unraveled thread (seems to work better once glue is dry).
Lots of pix, so two post since only 3 attachments per post (weird rule):
Shows the glue application split into two sections, 2nd done
Canvas right 5.jpg (197.27 KiB) Viewed 22814 times
second glue section about to be applied
Canvas right 6.jpg (156.91 KiB) Viewed 22814 times
Door jamb overlap started
Canvas right 7.jpg (136.22 KiB) Viewed 22814 times
Fred Trout
Postby Fred Trout » Tue Jul 14, 2015 2:17 pm
Second half of right side canvas application.
pix:
door jamb done
Canvas right 8.jpg (108.15 KiB) Viewed 22811 times
bottom section done
Canvas right 9.jpg (175.19 KiB) Viewed 22811 times
right side all done
Canvas right 9 done.jpg (119.25 KiB) Viewed 22811 times
Fred Trout
Postby Fred Trout » Tue Jul 14, 2015 5:20 pm
Finished all the vertical (sides) surfaces today. Tomorrow I do the roof & top of front angle with one piece of canvas if all goes well. Any time left over will be working on all doors.
And last one for today:
Front verticals canvassed
Canvas front 1.jpg (118.26 KiB) Viewed 22801 times
Fred Trout
Postby KCStudly » Tue Jul 14, 2015 8:03 pm
Looks great!!! :thumbsup:
Postby dales133 » Tue Jul 14, 2015 9:07 pm
Does look good.nice and smooth
dales133
Postby Fred Trout » Tue Jul 14, 2015 11:32 pm
Thanks for the comments. I am mostly pleased with the dry-wall fairing techniques but there are many places where my screwups still exceed the forgiving nature of a foamie :cry: Still early days and I have already noticed a couple of fingertip sized bubbles. Those should iron out hopefully.
The back door support posts look like crap atm and will need to work on the canvas overlaps but if the effort is made, should be able to get closer to approach a fiberglass smooth finish. As long as a quick rinse with a hose will remove the road dust, I will be satisfied even if it isn't all shiny-pretty.
Fred Trout
Postby Fred Trout » Wed Jul 15, 2015 6:49 pm
Finished the roof canvassing other than the fan cutout edge overlap and back overhang; that's going to take some time & patience so will save that for tomorrow.
Will be sanding and fairing out all the canvas edges that show so well on these photos. Hopefully not too many bubbles to deal with.
Pix:
Canvas top 1.jpg (119.19 KiB) Viewed 22748 times
Canvas top 3.jpg (107.52 KiB) Viewed 22748 times
view from the back - the "lines" are stop-start section glue edges - you can see the fan cutout about 2/3 the way up
Canvas top 4.jpg (90.26 KiB) Viewed 22748 times
Fred Trout
Postby Fred Trout » Wed Jul 15, 2015 6:53 pm
Work on door lockset cutout done - tested out OK; will canvas door in a few minutes if I have enough light.
Canvas applied to both sides; one edge glued, the other will wait for tomorrow.
pix:
Door canvas 1.jpg (92.07 KiB) Viewed 22727 times
Door canvas 2.jpg (89.16 KiB) Viewed 22727 times
Door lock cut-outs.jpg (99.27 KiB) Viewed 22748 times
Fred Trout
Postby KCStudly » Wed Jul 15, 2015 10:51 pm
Keep on rollin'. You're getting there! :thumbsup:
Postby GPW » Thu Jul 16, 2015 6:19 am
Covering is Fun eh !!!! :thumbsup: 8)
Postby dales133 » Thu Jul 16, 2015 12:16 pm
Nice work
dales133
Postby Fred Trout » Thu Jul 16, 2015 2:40 pm
Thanks for all the comments. GPW, it's fun until the bubbles pop or the little details get messed up (corner overlaps come to mind). Then it's just tedious and sometimes frustrating.
Completed trimming and gluing the door edges. Decided to trim the edges so the overlaps from the two sides did not overlap each other (split down the middle of the edge - was time consuming). That might have made the door fit more tight than needed. Anyway, it looks pretty good with plenty of room for paint & gasket. The door will stick out a bit to give the 1/8" gasket some room and since it is now slightly deeper than 1.5 inch (canvas x 2). There is a very slight warp in the top right corner (~ 1/16" - 1/8") - might leak because of it if I can not adjust the fit well.
Found some bendable white vinyl "L" molding that I plan to use as a over door/window drip rail. Will add a pic of it later.
Pix:
Will use nylon-dry-wall screws & caulk to stick this on
Vinyl molding for drip rail.jpg (156.69 KiB) Viewed 22662 times
Door in place (not mounted).jpg (183.81 KiB) Viewed 22679 times
Door in place (check fit & clearance).jpg (162.91 KiB) Viewed 22679 times
Fred Trout
Postby GPW » Thu Jul 16, 2015 3:15 pm
It'a all Good .... Better when it's Painted !!! :thumbsup: 8)
