That's my position and I am sticking with it. Yes, I am !!
mikeschn wrote:That's 1/2" sandy ply from HD. I don't think it's moisture resistant
mikeschn wrote:@KC, it gets better. I will be attaching the spars directly to the hard edges. The notches in the foam are strictly for locating the spars!
mikeschn wrote:what if we combine foam molecules with aluminum molecules?
todd432 wrote:I know they make PT plywood but it's not to flat
Fred Trout wrote:As long as we are brainstorming, I think we should use genetic engineering to invent plants or bacteria that grow-build stuff for us. Add the CNC instructions inot the thingmabob, water the plant, squirt the substrate into the bacterial vat, X days later, out pops our dohicky.
capnTelescope wrote:Hey Mike, your build is looking good already.I'm interested to see what all you do with the CNC on this build. Might get a few ideas.
capnTelescope wrote:Did similar on my build. Very pleased with the results. The cabin turned out very rigid in the sideways direction.
capnTelescope wrote:Do you get foamy aluminum or aluminum-y foam?![]()
capnTelescope wrote:The PT ply in my store wasn't flat at all.
GPW wrote:QUOTE: “ I hope GPW is right about canvas! “ ... Oh Gosh , what did I say now ???![]()
I think instead of inventing new things , we should deal with what we have ( or can easily get ) and make it work ... jury’s still out on square PVC ( it’s available )![]()
Using the mix on wood seals those pesky tubes...![]()
Mike , as you’ve said all along , using GOOD materials and doing your BEST work always makes a superior product ... Same goes for a Foamie ... even more so since all the parts have to work together as ONE to be effective ... either canvas or foam alone is unimpressive , but put them together properly and you have a remarkable result .
JMHO, I really BELIEVE everyone should start with a Simple Foamie , foam and canvas with a bit of sealed wood around the door, just to experience how really Super it works as presentedWith the door framing and possibly overhead ribs inside , it makes it Simple to build a serviceable and Practical camper trailer ... We’ve heard all the benefits already ... no use repeating that again (read the BIG thread) ...
Ps. We’ve even eliminated the idea of wood framing around windows now .... With proper fitting windows and that 3M marine sealant , our windows (FS) will have to be Attacked to remove them... Less framing means less to have to waterproof , and less to rot ...
mikeschn wrote:As for good materials, cost was not the object, weight was. And for sure, the way to make it light is with foam. I am going to watch Jack's aluminum over foam build though!!!![]()
mikeschn wrote:Fred,
What was I thinking? I should have built a 3D printer instead of a router. Then I could have just printed out a new teardrop!!! And I could print a layer of plastic, and then a layer of aluminum!
mikeschn wrote:Hi Capn,
Good to see you in this thread.
mikeschn wrote:How did you attach your walls to the floor? Oh wait, you didn't build a foamie! So you just attached them to the floor?
