MtnDon wrote:The specs indicate the compressor draws 11.5 amps and the fan 2.5. That's 14 amps. (Or depending on the exact model number suffix, it could be 12.1 or 11 amps for the compressor. I picked the middle ground)
The EU2000i is rated at 13.3 amps continuous. I think that even at 1000 feet it would lose enough power to make it difficult to run the A/C.
snowrider500 wrote:Has not tripped the 20 amp breaker in the trailer,
