I need a door trim close-up photo!!!
Postby bennelson » Fri Jun 02, 2006 9:29 am
Hi Everyone!
I am trimming out my doors and opening now.
My first try with it really didn't work out. I am pulling off my first-try trim and doing it again - right this time.
Can somebody please post a couple of nice close up photos of their door trim?
I have the Cubby plans, but the close-up photos aren't that great. I could really use a few nice shots of where the angles come together in the corners and how the t-molding meets on the ends.
It would really help me out, and I am kinda stuck until I get this figured out.
Thanks in advance,
Ben
still no idea what i'm doing...
bennelson
Images: 53
Postby bdosborn » Sun Jun 04, 2006 4:42 pm
Ben,
I have square doors so I'm not sure pictures of my trim is what you're looking for but I can post some pics if you think it will help.
Images: 806
Postby asianflava » Sun Jun 04, 2006 6:14 pm
I'm workin' on it fer ya.
asianflava
Postby asianflava » Sun Jun 04, 2006 6:22 pm
Ok I got them resized and uploaded. The wall side is 1X1/2x1/8 angle and the door side is 1X1X1/8 T-molding. BTW: I'm using Grant's offset hinges, with an 1/8in offset. The doors and walls are 1in thick
Just click the thumbnails:
asianflava
Postby bennelson » Tue Jun 06, 2006 8:52 am
Thanks Asianflava!
Some of these things are a little tricky to do without some good visualization first.
I got one door trimmed out, now I have to work on the weatherstripping!
-Ben
bennelson
Images: 53
Postby Bandit » Tue Jun 06, 2006 10:21 pm
My doors have a pretty tight radius so I had to not only anneal the aluminum, but I also kerfed the radius with a scroll saw. It works better to kerf before you anneal so the scroll saw blade does not grab the softened aluminum.
:thumbsup: :thumbsup:
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
Postby bennelson » Wed Jun 07, 2006 8:32 am
Hey Bandit,
It looks like you are only using angle on your door edge. That means you are using an inside seal, right?
Can you post an image of your inside seal?
I am using T-molding on the outside, but I think I want an inside seal too.
-Ben
bennelson
Images: 53
Postby Bandit » Wed Jun 07, 2006 5:04 pm
I'm traveling this week so not much progress on the WeekEnder. Back to it on Friday. I am using an oak frame to construct my inside seal. It will be trimmed, routed and finished to add to the inside appearance of the TD.
I decided against the T-Molding as it is not available locally and the angled molding is. MadJack made a good point of not kerfing the inside radius, and I will try this on the curbside door.
Bandit
Postby madjack » Wed Jun 07, 2006 6:50 pm
Bandit, remember it the outer trim piece, around the outside of the door jamb that does not need to be kerfed...you are pulling back, away from the bending leg and it will strech, if it has been annealed...on the trim around the door itself, try leaving around 1/4" of the leg, kerfing the rest...
...another tip to those who may not know...the only part that needs to be annealed/kerfed is that portion directly in the radius...
...good job so far...keep it goin'
madjack 8)
Postby Bandit » Fri Jun 09, 2006 10:15 pm
I tried annealing a piece for the outer radius without kerfing and it twisted and would not lay down flat when I tried forming it to the door opening. So. I kerfed it and it was very easy to form.
Bandit
Postby Endo » Sat Jun 10, 2006 9:52 am
Not sure if you still need photos but here you go. I moved my door handle "inboard" so I didn't have to notch the T-molding. I then made a strike plate for the latch. The hinge side of door has two seals, one one the door and one on the door opening. I formed the rain gutter to follow the profile of the door. The perimeter of the door only has the seal on the T-molding. I am happy to say no leaks yet!
Purchased all of the trim here.
http://www.teardropparts.com/sub-pages/ ... ldings.htm
Very easy to bend/form!!!!
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby asianflava » Sat Jun 10, 2006 2:09 pm
Hey, how come those corners don't have gaps in them?
Good job on those miters. :thumbsup:
asianflava
