today's update---- built the wood spine i mentioned a couple of posts ago. also--after mucking around with the 3/4" tubing, i decided that the results will be more satisfactory if i stick to the flat bar for the spine. graceful curves can be achieved quite easily, and are fast-n-easy to dial in with simple techniques. i would rather spend the time improving my welding skills than trying to achieve a perfect curve with the tubing.
for spinal rigidity, i can make the flat into T-bar by welding short segments of the same flat bar under the curve.
- dry dock 2.JPG (84.76 KiB) Viewed 2179 times
- dry dock 1.JPG (81.15 KiB) Viewed 2179 times
in the above shot, you can see that the curvature is a bit off. i want to have a long graceful curve from beginning to end---not the flat section over the door. with the flat bar, it's just a matter of moving some 2x4 blocks until it looks good. no fussing with the bender !!
- spinal radius 1.JPG (77 KiB) Viewed 2179 times
the radius here should be the same as the floor curvature.....
unscrewing the rear screw in those horizontal 2x4's means i can adjust the curve pretty easily with just a nudge up or down--- no kinks or flat spots.
thanks for the look !!
renaissance man-----MUST....MAKE......EVERYTHING !! (wife interjects here---"EXCEPT MONEY !")
