The Mad Dash begins...
Re: The Mad Dash begins...
Postby mikeschn » Tue Aug 04, 2015 7:38 am
GPW wrote:Good Plan !!! Good to have a plan !!! 8)
Nothing like starting with a vision of the end in mind!!! :D
Actually, this is how I came up with it...
Aug 29 & 30
Canvas Doors and Hatch
Aug 22 & 23
Build Doors and Hatch
Aug 15 & 16
Canvas Body
Aug 8 & 9
Assemble remaining body
Aug 1 & 2
Glue up walls and spars
Sounds easy, right? Alas, anyone who has built one knows I am missing a whole lot of details!
Postby KCStudly » Tue Aug 04, 2015 8:30 am
Details? Did someone say details? :? :R
Postby Fred Trout » Tue Aug 04, 2015 10:13 am
Mike, I can never accurately predict how long something will take; you need lots of experience doing things over and over (that I don't have) to be a good judge of that. You have a better idea of how doable it is than all us 'never done it before types'.
Most of us always spend so much time setting up and taking down the staging and prep for certain construction step knowing that this is not getting the job done. Having a plan always helps, so you have that going for you as well :)
Fred Trout
Postby mikeschn » Tue Aug 04, 2015 6:20 pm
Couldn't stand it!!! Had to glue in another roof panel, sans kerfs!
Postby mikeschn » Tue Aug 04, 2015 6:28 pm
Also finished the window panel!!!
Postby GPW » Tue Aug 04, 2015 6:30 pm
Looks GOOD !!!!! :thumbsup: 8)
Postby mikeschn » Tue Aug 04, 2015 6:44 pm
Dry fit to see if things fit...
Postby Fred Trout » Tue Aug 04, 2015 11:09 pm
Looks like it fits pretty well :thumbsup:
Hey Mike, do you sand smooth that CNC router pattern or does the canvas cover it without showing through ? I don't recall what weight canvas you bought & could not find it mentioned.
Fred Trout
Postby capnTelescope » Wed Aug 05, 2015 12:09 am
Front window looks good, Mike. :applause:
I'll say one thing about you foamies: you sure do a lot of sanding. :lol: 8)
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby GPW » Wed Aug 05, 2015 5:24 am
Capn’ ..... but sanding is so EASY !!!! :dancing
Postby KCStudly » Wed Aug 05, 2015 7:15 am
Always wear your respirator and do a good job cleaning up with the shop vac afterward. That stuff goes everywhere.
Postby GPW » Thu Aug 06, 2015 6:31 am
Foam Dust is nasty stuff ... gets EVERYWHERE... :o Beaded foam beads stick to you and everything else ... I had that “snow" around my yard for months ... :duh:
Two components to foam .... Plastic and Air .... the only thing that sands is the plastic , and you don’t want to breath Plastic , now do we ... :frightened:
Postby mikeschn » Thu Aug 06, 2015 7:28 pm
Well, we're driving home from work, and Chell says she has tomorrow off! Instantly I got jealous. Geesh, if I were off too, we could work on the foamie teardrop. So I took the day off, and we are going to do a 3 day build blizzard!
So we got home, and first thing we did was glue in the window panel...
Tomorrow I'm hoping to glue in the panel on each side of the fantastic fan, and the lower panel under the window panel.
Then I imagine we'll pull up a chair and stare at the foamie for a while...
After that? Who knows, maybe we'll start the hatch???
Postby KCStudly » Thu Aug 06, 2015 7:58 pm
You're almost done! :applause:
Postby mikeschn » Thu Aug 06, 2015 8:04 pm
KCStudly wrote:You're almost done! :applause:
lol, I hardly think so. What about the hatch? The doors? The canvas?
