Werdahekrwe wrote:Thinking again.After looking at a post about a "standie" w a drop floor, I'm wondering how I might lengthen the tongue for the "FOAM DUCK" And still use a drop floor so I can get it into the garage. Wondering if I could use a "squared Y" shape extension which would come to the front cross member of the HF frame, then use a cross bar (bolted and/or welded to the frame) with two arms going back to almost the axle/spring mounts. Also, could heavy bed frame raols be used for the cfoss member and arms? The wZy I figure it would have and inside height of 5'6" and 5'8"+. DW and I are both 5'4" or less.
