The Mad Dash begins...
Re: The Mad Dash begins...
Postby GPW » Fri Aug 07, 2015 6:41 am
Coming Along Nicely !!! 8) Front window is a Nice idea eh !!! :thumbsup:
Postby mikeschn » Fri Aug 07, 2015 5:14 pm
It's been a long day out in the hot sun, standing on the hot asphalt.
We glued in the last front panel (the one under the window panel). We also glued in the two top panels, one on each side of the fantastic fan, after framing it in to the final size of 14 1/4" square.
We did a little bit of sanding on the doors, and glued the woods strips on the top of the door. A little more spackle and some sanding and they will be ready for canvas.
Then we worked on building the hatch... Here you can see the notches for the spars...
Spars are glued in...
Enough work on the hatch for one day; but you can see the foam is already cut...
I also glued in the foam corners for the windows. I'll trim them a bit more tomorrow.
Postby GPW » Fri Aug 07, 2015 5:32 pm
Oh, I see now .... Clever fit on the hatch frame .... very COOL !!! :thumbsup: 8) :applause: :beer:
Postby mikeschn » Fri Aug 07, 2015 5:42 pm
GPW wrote:Oh, I see now .... Clever fit on the hatch frame .... very COOL !!! :thumbsup: 8) :applause: :beer:
Hey Glenn,
I think I'm am going to try your trick with the hot air gun and bend the foam, and see how much it retains the bent shape.
P.S. Glad you like the hatch design! :thinking: :D
Postby GPW » Fri Aug 07, 2015 5:48 pm
Mike, try heating both sides at once and bend a little area at a time ,inside and outside the bending area ..... You can feel the foam "give" when it's bending , and if you hold or clamp it in place till it completely cools , it'll stay right there... Keep the heat gun moving , and it won't burn . Good Luck !!! Good Bending !!! :beer:
Postby mikeschn » Sat Aug 08, 2015 5:05 pm
Spent the whole day outside without much to show for it...
We've got spackle all over the place...
and I made a giant boo boo... Didn't have a solid mount for the foam on the bottom of the hatch. So I had to hand whittle out a rabbet, 3/4" x 1 1/2". I'll glue in a special spar tomorrow... :oops:
Musta been the beer... :tipsy:
Postby KCStudly » Sat Aug 08, 2015 6:13 pm
That'll buff out easily enough. Looks like good progress to me. :thumbsup:
Postby capnTelescope » Sat Aug 08, 2015 8:38 pm
mikeschn wrote:So I had to hand whittle out a rabbet...
Failure to fully think ahead. Don't you hate it when that happens? :fb That's on a par with the hinge block mod for my hatch prop. :oops: At least this won't show. :thumbsup:
KCStudly wrote:That'll buff out easily enough.
:lol: Start with a piece of foam and buff out anything that doesn't look like a teardrop. :R
You'll get the last laugh when your trailer weighs half of mine. 8)
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby mikeschn » Sun Aug 09, 2015 2:32 am
:lol: Good one!
capnTelescope wrote: :lol: Start with a piece of foam and buff out anything that doesn't look like a teardrop. :R
Postby GPW » Sun Aug 09, 2015 7:00 am
Mike , did you bend that with heat ??? :thinking:
Postby mikeschn » Sun Aug 09, 2015 6:56 pm
I didn't think it would be such a long day today, but, it was!!! :o
Early this morning I fixed the bottom of the hatch. Then we did some spackling, and some sanding. Then we canvased the doors
Next we started the canvas on the ceiling. What a pain... that's hard work..
Then we bailed out and went for the easy! We canvased the roof. Yea, I like it.
Postby KCStudly » Sun Aug 09, 2015 7:10 pm
Almost done! Zowie, you are moving along quickly! :thumbsup: ... and with no sign of compromise in quality. :applause:
Postby capnTelescope » Sun Aug 09, 2015 8:38 pm
I'm enjoying the pace of this build. Mike just keeps moving along. :thumbsup: :applause:
Can't wait to see what he does in the galley.
Brad
capnTelescope
Images: 368
Postby GPW » Mon Aug 10, 2015 5:23 am
:thumbsup: This one is going to be Light !!! 8)
Postby dales133 » Mon Aug 10, 2015 6:58 am
This build is lightning fast and a seriouly cool looking camper
dales133
