mikeschn wrote:Did Bonnie ever add a window to that Nookery?![]()
bonnie wrote:mikeschn wrote:Did Bonnie ever add a window to that Nookery?![]()
No window as of yet. I did add a hatch on the back to put the AC through. I am trying to decide what to do. I could use a bit better cross ventilation. The tiny window doesn't open.I may add a window in the door.
mikeschn wrote:Dale,
For large areas like the sides, I use a roller. I've tried the adhesive rollers, but prefer the standard rollers. Use 1/4" nap or 3/8" nap. Yea, your going to lose a little bit of glue due to the roller sucking it up, but you need the roller for speed, and ability to apply glue thick enough. I used 3/8" nap on the outside of the Mad Dash, and put the glue on nice and thick, and it worked well. My 10 oz canvas even shrank a little bit, giving me a nice taut finish! I used the glue full strength.
GPW wrote:Dale , just a standard roller works fine ... or a brush (more work) ... Remember to thin the T2 a little to get it to roll easily ... You can see how well it worked for Mike ^ .... me too ... You want 100% coverage of the glue , no dry spots ... The Glue is one of the cheapest components so don’t stint on that ...
