lrrowe wrote:Bruce, your trailer setup and results is neat!
Java Jack wrote:Awesome. What are you using as your source? Your PC?
bdosborn wrote:Java Jack wrote:Awesome. What are you using as your source? Your PC?
I'm using a WD TV Live with a USB drive attached. AND, unfortunately its out of production too. Which is a shame as it plays just about any file format, streams Netflix and runs on 12V. WD has a replacement version that's not quite as flexible with file formats and doesn't have Netflix. I'm phasing it out of the home theater setup and replacing it with an HTPC running Plex. The trailer might see something like an Intel NUC running Plex someday down the road.
bdosborn wrote:I've been trying lot of different media boxes lately, its kind of turned into an obsession.
I tried the Roku for streaming to the bedroom TV but I didn't like it as much as the WDTV. I didn't like how half the start screen is an ad and it seemed like the search function always steered me towards pay-per-view. I didn't try it with a the USB drive, I'll have to take another look at it. I replaced it with an Amazon Fire Stick, which I like a lot. It has a snappy interface, runs Plex and hardly ever needs to be rebooted.
I played around with a Rasberry Pi 2 running Plex. It has potential but I found mine needed to be rebooted *a lot*. I got sick of hoping it would work each time I fired it up.
I tried a Chromecast for the HT and its a pretty good streamer. It will stream 1080P Plex from my phone but I have an older audio amp that doesn't have any HDMI connections. As a result I couldn't get 5.1 surround using the Chromecast. It was replaced with an HTPC so I have a fiber-optic connection to the audio amp. The HTPC looks like a keeper for the HT.
The WDTV really shines playing from a single USB drive or streaming Netflix. It usually just works, all though the interface is slow. It doesn't work nearly as well connected to a NAS (crashes a lot). The WDTV is sitting there unplugged while I make up my mind about which device I like best for each TV. The WDTV in the trailer is connected to our home network so I can transfer movies to the connected USB drives while sitting on the couch. That's a cool feature of the WDTV, Windows sees it as as a network hard drive.
My wife goes crazy trying to watch TV as I'm always changing something.I'm getting closer to cutting the cord, I just need to get a setup that the wife buys into.
