Well, after 11 hours of sleep in the teardrop last night it was time to get back to work.
But first we had to do a trip to the Orange Box store for supplies...
and JoAnne Fabrics for materials for the curtains!
Then back home and the work started...
I poly'd the divider for the shaker bench, and also the 1/8" plywood wall that divides the galley from the hatch.
Redid the door handle to add a barrel bolt. Installed the roof vent (with caulking).
Everything else was about electrical. Chell is the electrician. But I do a lot of installing cable clamps, drilling holes, etc...
And then the rain came!
Here's the empty galley
Here's a view from the inside... I still need to put down a small board at the bottom where the light is shining in...
Oh, here's one I haven't shown you yet... As you know we have wheel wells, and it's kinda hard to fit the bed inbetween the wheel wells. So we put 2 layers of foam down on the floor, to raise it to the height of the wheel wells. Then we put the mattress on top of that! That worked out perfect! We didn't have to cut the mattress!!!
