Ok here we go...PMF!
Re: Ok here we go...PMF!
Postby Sheddie » Sat Aug 22, 2015 5:34 pm
Are they sitting in cut outs to stop sideways movement? So you would be likely to have water come through there? :thinking:
Sheddie
Images: 1129
Postby Sheddie » Sat Aug 22, 2015 5:59 pm
I just had a look at their PDF, I see they are made for vertical use so those grey bits will be what stop them sliding apart. They talk about the issues of getting grit in the gears if they are cut and that if they are cut that the cut end should be at the bottom so that any of the filings would fall out away from the gears. They also mention issues with paint in the gears. It makes me wonder about the stability of them for the hatch, with road dust getting in go the gears. :thinking:
Sheddie
Images: 1129
Postby dales133 » Sat Aug 22, 2015 6:07 pm
They are like rebates but there is a small cut out at the top of them.
I didnt realise the extent of the holes until i got home but im thinking of a way to get around them.
Worst comes to worst i could cover it with rubber and a couple of strips holding it down similar to what kcs doing but id prefer not to.
Installing the hatch spar ceiling and some wiring today i hope
dales133
Postby dales133 » Sat Aug 22, 2015 6:12 pm
I didnt realy think of tbe road dust issue but on shop front doors ect youd assume they would collect a fair bit of crap.
Im thinking i might be adle to make some sort of covers to go over the ends... not sure.
Before i cut it ill investigate further
dales133
Postby dales133 » Sun Aug 23, 2015 5:13 am
Got a good deal done today and mostly the dreaded 12v electrical, not my forte at all.
Fixed up my oversite of not wiring the fan up after routing it out and also added 3 small cabinett lights in my internal shelves including mounting and wiring the switch for them,interior light,porch lights and internal switch,car audio...
Vacumed it all out and other than mounting the 2 front reading lights and headboard and tv the interiors finished.
I also mounted my FConector through wall conecter socket for the tv Ariel.
So next day at it ill fit the ceiling over the cupboard after tripple checking everything then hatch spar,foam and roof ply + the last of the roof PMF.
Some of these smaller jobs take forever.
I didnt pack up until 5.30 and started at 9
dales133
Postby dales133 » Sat Aug 29, 2015 6:11 am
Got the last of the ceilung in today after havi g a bombsite cleanup and fitting some ratchets to my new roofracks.
Then i machined up and installed the hatch spar and cut the outter ribs to size.
Tomorrow i hope to get started on the hatch ,i picked up the canvas for the sides friday arvo too
dales133
Postby Atomic77 » Sun Aug 30, 2015 11:02 am
So where's your pictures my friend? ;)
Keep up the good work. I'm jealous of your progress. Mine is sitting in storage for at least another month.
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby dales133 » Sun Aug 30, 2015 11:10 am
Atomic77 wrote:So where's your pictures my friend? ;)
Started my hatch build today ,a little unconventional but you may have noticed its a common thing with me
dales133
Postby Atomic77 » Sun Aug 30, 2015 1:07 pm
Oh yeah... That's looking good!
Michael
The Astroliner
Atomic77
Images: 309
Postby Sheddie » Sun Aug 30, 2015 4:26 pm
Hi Dale, I see you were asking Tim about the latch for your hatch. GoughTWL have that sort of thing. Have a look at their body hardware catalogue.http://goughtwl.co.nz/catalogue/body-hardware look on page E28. You have Gough Transport Solutions in Australia, and the head office is in Melbourne. I would think they should have all the same stuff in Aus that we have here. It was GoughTWL in NZ that I got the door stops from for my side doors and for Tim.[url]Vitoria (Head Office):9/450 Princes Hwy, Noble Park 3174[/url]
Sheddie
Images: 1129
Postby KCStudly » Sun Aug 30, 2015 4:38 pm
Looking like a good start on the hatch! Build on! :thumbsup: :applause: :thumbsup:
Postby dales133 » Sun Aug 30, 2015 5:34 pm
Thanks muke ,kc cheers frank that place is great.
How did you find the 2 way latch?
The schmatics a bit crap to view on my phone.
Can you use a rear fix t handle with it?
dales133
Postby Sheddie » Sun Aug 30, 2015 8:18 pm
dales133 wrote:Thanks muke ,kc cheers frank that place is great.
Unfortunately I didn't find that latch until after I had made my own, using a garage door handle, with a piece of stainless plate for a "T" inside the hatch, some spring loaded door catches and some s/s fishing trace to pull on the catches. One day I may get one of theirs and replace it.
It has a square hole in the centre, that goes through, so that you can have the latch on the inside and the handle through from the outside. Next time you are around that side of Melbourne, I would suggest you call and see them. If you scroll up, they have a variety of handles, and if you scroll down, you will see the door stops.
Sheddie
Images: 1129
Postby dales133 » Mon Aug 31, 2015 5:39 am
Yea i had a good look fabulous resource.
I need a bunch of stuff for the trailer to.
Unlike you sensible people i have to take the td off the trailer in a week or so and fit the trailer floor then build the draw slides and draws and everything else.
Im a glutten for punishment but i know what i want and i can see the finishline
dales133
Postby dales133 » Mon Aug 31, 2015 5:44 am
Ive also picked up a job to build a verry basic box camper for a customer who wants to use it for hunting.
Its going to be 8x4 on a premade new trailer and my mates welding up the frame.
Im cladding it in composite pannel and fitting a tear drop door to the rear and two sliding windows,one each side.
Probably went in too cheap but hes finnishing it off. Im just making it water proof and useable
dales133
