Tomorrows objectives, install the door jamb, do final edging on hatch (two strips), final fairing and paint. If I get this done I should be ready to canvas the outside Thursday
ghcoe wrote:For anyone that may want to run separate turn signals on their trailers with conventional combined brake/signal wiring.
This is the product you will need, a Vehicle to Vehicle Tail Light Converter http://www.etrailer.com/Accessories-and ... 56196.html . If you are using it for a trailer and not for towing a vehicle you do not need the recommended diodes. I think I will use this one so that I can use the trailer easily between different vehicles.
OP827 wrote:This sounds great, thanks. Could you please share the schematics details of this setup when you do it. I am thinking of doing the same, but I am behind you with the wiring, so if it works for you, I will do it too![]()
Nice progress and I like how you install the cutout wiring channel foam piece back with acrylic caulking. This is much simplier than using a router etc. Great ideas, thanks for sharing!
