I will go over the technique again here so it flows well.
I find that thinning the TBII 50/50 with water works really good for this technique. It allows the glue to get into the canvas and it dries slower, which in my case is good since I am working alone and it is a bit slow going. I find that by time I go through a complete cycle that the glue is getting tacky. When it is tacky it seems to grip and hold better once the two glued surfaces come together.
To get started I applied glue to the canvas as it was sitting on top of the trailer and then glue to the top portion on the side of the trailer. I am working with a 4" brush and I try to apply the glue two brush widths wide at one time. This applies enough glue to the side of the trailer to allow for how much glue I apply to the canvas. I also apply to the canvas first and then to the side of the trailer. This cuts down on glue running down the side and the glue getting too tacky. Then I just rolled the canvas of the top off the trailer. The rope should hold it now.
Now it is glue the canvas as far around the roll as I can.
- Painting the canvas
- DSCF3709.JPG (155.36 KiB) Viewed 7358 times
Once the canvas is glued it is time to apply glue to the wall.
- Wall and canvas painted
- DSCF3710.JPG (152.61 KiB) Viewed 7358 times
I make sure that the canvas weave is filled with glue as pictured.
- Canvas saturated
- DSCF3715.JPG (157.79 KiB) Viewed 7358 times
