Hello Everyone,
I have a 78 x96 semi standee trailer. A few years back I discovered a leak on the roof a bit too late and the interior was moldy. Here in Florida it takes no time for mold to develop with the humidity and heat. I have been fixing the interior as time permits, since I travel internationally a lot. Well, last year I thought I was finished and was doing a once over and discover another leak. Well I took all the interior apart, again, and has been empty for a while. Recently I found and excellent option for a bed, an IKEA Beddinge sofa bed (http://www.ikea.com/us/en/catalog/products/S29089426/ ) , and will fit width wise with a little trimming. The problem I have, is the length, from day one I wished the trailer was 120", since that would be the perfect length for me. I had a welder add a rail cage, in front of the trailer to carry the spare, miscellaneous items and battery, the frame is made of 1.5 "angle steel and is close to 1/8th. What I have been pondering is to remove the front, which would be very easy at this junction and using that frame add the extra two feet I need. Obviously, I would have to reinforce the sides, my trailer is made out of 2' aluminum studs and 1/8 luan covered with Filon. There are some pictures of my trailer in my gallery. I am thinking to use .040 painted steel to add the extra length and cover some delamination I have also on the frot due to the leak.
My concern is how much of an impact extending the body of the trailer an extra two feet will be on the stability of the trailer. The front will be fairly light, since I am planning ti keep the kitchen on the back and just build light storage up front. I will appreciate any comments and advice you can provide.
Thank you ,
Ed
